Results 1 to 10 of 10
Thread: Portable water needed!
    Dec 2004
    69
    Portable espresso water supply .... just talking to a concert venue and they asked if I was prepared to bring in my 2 group machine etc ... but theres no available water supply. Is there a simple solution? What do these vans do?
    any input appreciated
    cheers
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Portable water needed!
    Quote Originally Posted by 2726242A3D4F0 link=1263190112/0#0 date=1263190112
    Portable espresso water supply .... *just talking to a concert venue and they asked if I was prepared to bring in my 2 group machine etc ... but theres no available water supply. * Is there a simple solution? *What do these vans do?
    cheers
    A water tank... Just like a Caravan or hard core 4X4 users...
    Dec 2004
    69
    Thanks ... does it need to be pressurized? eg to standard mains pressure?
    14,665
    Quote Originally Posted by 353436382F5D0 link=1263190112/2#2 date=1263192065
    Thanks ... does it need to be pressurized? *eg *to standard mains pressure?
    Depends on the pump in your machine. At very least, your pump will require adjustment to compensate for lack of mains pressure.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 114E56404B404C454546464E424D230 link=1263190112/3#3 date=1263192160
    You also have to make the choice... Fill tank with filtered water or put an in-line filer in, between the tank and ya machine..
    Depending on what your trying to do... Both have pros and cons.. One being potential adjustments to the pump on ya machine... As per 2mcm.
    Dec 2004
    69
    thanks for your input .....
    have been googling camper trailers for showers etc and have come up with a Flojet and subsequent filter system - 50 litre food grade plastic container, through Flojet to inline filter and on to the machine.
    Sounds pretty falwless and I dont have to change the machine pump at all
    how does this sound?
    thanks
    Jul 2007
    2,288
    That should work--the flojet pump systems have been used to feed rotary pump espresso machines successfully.
    Dec 2007
    921
    You will need some way of filling the tank also dont forget and 50L wont last forever so depending on numbers you may need additional water on hand during the event. Just did what you are thinking over a 5 day period with no issues.
    Aug 2009
    15
    If you havent already solved your tank/water issues, try having a look at the CAMEC website, particularly in their Plumbing Catalogue Section and youll be able to go nuts with sizes of tanks, pumps, filters, etc.
    They are at Caringbah and Engleburn but could be worth the drive. Also, you may get an idea and find a local supplier.
    Peter
    Dec 2009
    18
    We have a 2 group Expobar megacrem compac.
    We use a filter to fill a couple of 20L cubed plastic camping containers (easy to handle) and these are placed under the bench. The machine, without any modifications, pulls the water straight from these. Hence there is no need to plumb in a filter between the water and the machine.
    20L will get you just over 100 coffees as long as you are not using your water to make lots of cups of tea or too many long blacks.
    Our filter is the one that came with the machine and would normally be plumbed in, but we have set it up with hosing and a tap nut that fits most outdoor taps so that we can take it anywhere, connect it to a tap and then fill directly into our 20L containers as needed and hence dont have to carry large volumes of water (not that we do this too regularly as we have rainwater at home and prefer to filter this and take it with us, as it definitely makes much better coffee). We also dont need to be set up near a water supply, all we need is a tap within walking distance, if we think we may run out of water
    If your machine is able to pull straight from a container and you are not planning on doing lots of events and hence dont want to spend dollars on containers, filters and plumbing gear, it may be cheaper to just buy a couple of those large filtered bottled waters that fit onto bubblers (if you understand what I mean?).
    Hope you have lots of fun and good luck
    Denhamia
  1. rain water and coffe machines - decalcify needed?
    By Markh in forum General Coffee Related...
    Last Post: 9th April 2016, 04:55 PM
  2. urgent help needed re Lelit water tank
    By Penny_Waites in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th May 2011, 12:32 PM
  3. Silvia Water Temperature - advice needed
    By SamR in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th September 2009, 06:50 PM
