Results 1 to 11 of 11
Thread: Calibrate Grind Settings on a Cold Machine
    Jun 2009
    37
    Can a cold machine be used to calibrate the grind setting for a particular bean?
    Say I know Im going to be in a hurry one morning but have a new bag of beans on the bench so wont be able to pull a couple of trial shots then. Would I be able to run a couple of shots through a cold machine the night before to get the theoretically correct setting (i.e. xx ml in xx seconds)?
    hazchem
    Re: Calibrate Grind Settings on a Cold Machine
    Quote Originally Posted by 62656A677D74656A7077040 link=1263894010/0#0 date=1263894010
    If youve got time the night before to make start dialling in the new beans, why not do it with a hot machine? I doubt youd be able to dial in a new blend or single origin accurately without bringing your machine up to temp first.
    Senior Member topshot's Avatar
    Jul 2007
    Currans Hill, NSW
    369
    I cant see why not, you wouldnt be far off the mark.
    The resistance of the tamped coffee to hot or cold water *will be the same ;)
    Warren.
    Jun 2009
    37
    Quote Originally Posted by 2B2239202B262E430 link=1263894010/1#1 date=1263897656
    Yeah, its pretty much a hypothetical question so I wouldnt bog down in the details too much. I was in the kitchen before and I was thinking that I could take the opportunity to sort out my grind but couldnt be arsed waiting for the machine to warm up.
    The question was more about whether temperature affects extraction times or only extraction flavour.
    Quote Originally Posted by 372C33302B2C37430 link=1263894010/2#2 date=1263897704
    Cheers for the response.
    Jun 2008
    1,520
    Quote Originally Posted by 415A45465D5A41350 link=1263894010/2#2 date=1263897704
    Although i have NFI about any scientific reason, i reckon the hot water would effect extraction enough to need to "dial in again" in the morning.
    I would have thought viscosity (and expansion of puck) of the extraction is going to be way different and thats going to effect your grind, IMO you will be grinding to fine in cold water for when you heat it up.
    set you alarm for 10 mins earlier to ensure you can pull a few extra shots......
    if you do a "cold" grind set up let us know how it goes i am interested int the findings.
    taste them for us too please :)
    Leeham
    hazchem
    Quote Originally Posted by 5458515C5C55390 link=1263894010/4#4 date=1263900504
    taste them for us too please *
    thats where I think the kicker is. You might get close in times with a cold machine but it isnt going to taste right at all.
    10,496
    Quote Originally Posted by 534857544F4853270 link=1263894010/2#2 date=1263897704
    Warren.
    That makes sense to me reading it Warren BUT....
    My machine is on a timer and on more than one occasion Ive tried to get away with pulling a shot before the machine is back up to full operating temp and it doesnt look right when it pours.
    IIRC the pours were "runny" not "dripping".
    This despite the fact that the e61 head was still fairly hot before switching back on.
    Dec 2004
    Earth!
    16,191
    Doing a pull with a cold machine will not yield the same extraction profile as with a properly warmed up machine. The grinds will not absorb the water as fast/as completely as they do with hot water. Not to mention that the grind setting will most likely change over night anyways due to environmental factors.
    Java "Extractions R Us" phile
    Site Sponsor
    Jun 2006
    257
    Id say not and prior trails of dailing in a grind with a machine warming (read: not fully up to temp) have proven unsecesfull to dail in the first grind of the day.
    I know of somewhere that always has a bit of coffee on hand.. next time your around lets test it and document! Wont even be at fault this time if the machine isnt turned on. ;D
    Jun 2009
    37
    Quote Originally Posted by 05352E202F332235142E2322470 link=1263894010/8#8 date=1263928297
    next time your around lets test it and document! Wont even be at fault this time if the machine isnt turned on. *;D
    Sounds like an offer I cant refuse; will see you later in the week and report results back to the forum in due course.
    Jun 2009
    37
    So I took Roger up on his kind offer some time ago but have not yet reported the results.
    Bottom line: unless the machine is heated to its proper operating temperature, you can infer nothing with regards to grind settings. Javaphile was spot on.
    We tested on a cold machine for a given grind and the water gushed through the puck with the resulting brew resembling dishwater. Ill apologise, neither Roger nor I were game to try the shot.
    So my inference here is that even if youre almost at proper temperature, the grind setting will differ from when youre at proper temperature.
    I could be wrong, but this could also explain my experiences with the second shot of the day running a little slower than the first with all components brough up to temp by the first shots brew water.
    Anyway, it was certainly fun experimenting.
  1. EM 0480 grind settings?
    By Zaneus in forum Grinders
    Last Post: 18th December 2010, 09:14 PM
  2. Grind settings for different beans?
    By redzone121 in forum Grinders
    Last Post: 16th December 2009, 06:42 PM
  3. Different grind settings
    By mmmcoffee in forum Grinders
    Last Post: 14th July 2009, 01:32 PM
  4. Beans and grind settings
    By matblack in forum Grinders
    Last Post: 19th June 2007, 02:12 PM
  5. [m]: Grind settings for plunger???
    By Dimal in forum Grinders
    Last Post: 15th March 2007, 09:19 AM
