Results 1 to 15 of 15
Thread: Stuck puck
    Jan 2010
    59
    Stuck puck
    Hi all, i need a little info, im having a problem with my pucks sticking to the shower screen on my em6910, every shot i pull i have to scrape the puck off the screen and the group handle is empty.???? any ideas
    Thanks Josh
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    Re: Stuck puck
    Dont really know and I dont have an em6910...
    but are you overdosing? (Do the 5 cent piece test - search for the test on here if you dont know what that is.)
    Apr 2008
    Brisbane
    5,115
    Re: Stuck puck
    Quote Originally Posted by 2935382F38393E3C2D2E343E28305D0 link=1264455818/0#0 date=1264455818
    Thanks Josh
    Use less grounds
    If you are overdosing you are literally pushing the puck into the screen
    Others may have other advice as there may be other issues
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Stuck puck
    Quote Originally Posted by 7E4F584140474C41572E0 link=1264455818/1#1 date=1264457368
    Agree... The 5 cent test is an ideal starting point.
    I also thought the same as KK, but a few other EM6910 members demonstrated otherwise... Yep, I got it wrong...
    If ya got a good grind and firm tamp etc and you under dose... Yep underdose.... The puck can lift out of the basket and stick to the screen...
    Sound a bit funny... But with a bit of practice.. I could recreate it on demand..
    Not sure if TG also found the same.. Will see if I can find the post.. Some time ago... 12 or 18 months...
    Hang in there.. The EM6910 will do you well if ya treat it right...
    Jun 2009
    214
    Re: Stuck puck
    Hi therepcapsican,
    I use to have the same problem. AM is right here. Its due to there not being enough coffee in the group handle which results in the puck not expanding as much and hence sticks to the screen.
    I overcame the problem by adding a bit more coffee so you can only see half of the sunbeam tamper stainless steel part.
    So try updosing and let us know how you go. :P
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Stuck puck
    Quote Originally Posted by 3B342F233B3E3B2C5A0 link=1264455818/4#4 date=1264458654
    Hi therepcapsican,
    Here is the definitive answer.. * peteru posed the question in 2008... A number of us came up with interesting posts *;D * peteru found the answer and posted it.. *I had to try it caus I am anal on some things... * peteru was 100% *;) [smiley=tekst-toppie.gif]
    ANSWER * http://coffeesnobs.com.au/YaBB.pl?num=1226019023/30#30
    Read the whole post here http://coffeesnobs.com.au/YaBB.pl?num=1226019023/
    Apr 2008
    Brisbane
    5,115
    Re: Stuck puck
    I suppose that if you under-dose the top of the puck could become wet & sticky (glue like)
    When it expands it gets stuck in the screen
    also it may not have enough weight to release that grip the screen has on the puck
    Jan 2010
    59
    Re: Stuck puck
    Thanks to everyone who has replied, i think your right AM with the under-dosing, i am getting sloppy, wet sticky pucks also, will try upping the dose and will let you know.
    Josh
    Jan 2010
    59
    Re: Stuck puck
    AM just had a look at that link you posted from 2008, sound exactly the same as whats happening to me. let the testing begin... ;)
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Stuck puck
    Quote Originally Posted by 667A77607776717362617B71677F120 link=1264455818/7#7 date=1264462507
    Josh
    Not me -*peteru and JavaPhile ... I just confirmed along with a few others as to the EM6910..
    Take care and let us know how ya go..
    Feedback is GOOD for all.
    Jan 2010
    59
    Re: Stuck puck
    Well after 4 back to back test i can tell you with out a doubt that i was under dosing, i now have a nice firm puck that stays in the group handle ;D,
    thanks to all for the advice.
    Cheers Josh
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Stuck puck
    Quote Originally Posted by 160A07100706010312110B01170F620 link=1264455818/10#10 date=1264465427
    Cheers Josh
    Thank peteru next time he is on or send him a PM... I am sure it would be welcome..
    Jan 2010
    59
    Re: Stuck puck
    Done, thanks
    10,496
    Re: Stuck puck
    Quote Originally Posted by 745B52504778545B54525058505B41350 link=1264455818/5#5 date=1264458870
    peteru was 100%
    and TG was 0% ;D
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Stuck puck
    Quote Originally Posted by 1529342F252433262E25410 link=1264455818/13#13 date=1264488199
    peteru was 100%
    and TG was 0% *;D
    So was AM
  1. EM6910 stuck puck
    By peteru in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st December 2010, 01:30 PM
  2. Single basket, stuck puck
    By JJJ in forum General Coffee Related...
    Last Post: 1st July 2010, 11:23 PM
  3. Puck is Stuck
    By ento in forum General Coffee Related...
    Last Post: 24th November 2008, 09:35 AM
  4. stuck basket
    By Sunbeamer in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd October 2007, 11:42 AM
