Results 1 to 12 of 12
Thread: Maximum freshness for low volume consumption.
    Apr 2008
    370
    This thread applies to people who:
    1) Have a ready supply of fresh (<3wk from roast date) coffee.
    2) Grind on demand.
    3) Does not store beans in the hopper.
    The problem is that the grinder tends to build up ground coffee inside the machine. That ground coffee goes stale in under an hour, and if you are only having two coffees a day, your coffee will always have some of this stale grounds falling into the filter basket.
    Ive recently figured out a way to have the most consistent and fresh coffee despite only having two shots a day while minimizing the amount of coffee wasted.
    Heres the trick:
    1) Measuring: Use a filter basket of the same size to scoop beans in to the grinder. Scoop slightly more than you need (a few tries and you will get a feel of this).
    2) grind-dose-level-tamp-pour the shot. Drink your coffee.
    3) LEAVE the little bit of whole coffee beans in your grinder.
    Now the next time you have a shot:
    4) Switch on the grinder and whatever comes out, throw it away. The whole beans still in the grinder are alot fresher than the stale ground coffee cought in the burrs. It sort of flushes out all the stale grounds.
    5) Repeat 1-4. This ensures a minimal amount of stale coffee goes into each shot.
    10,496
    Re: Maximum freshness for low volume consumption.
    Close to what Ive been saying for ages.
    1) Measure into spare same sized basket (just enough).
    2) Brush out grinds caught in chute.
    3) Dose-level-tamp-pour the shot. Drink your coffee.
    4) Repeat 1 - 3. No stale coffee goes into each shot.
    Apr 2008
    370
    I had a laugh awesome.
    Im sure that method would work for most grinders.
    Im using the budget 4080 grinder so there really is a grinds retention problem. As in, you could not possibly brush the grounds from the last grind out of the grinder unless you open it up. If you brush from the chute, no matter how thorough you are, one simple jerk back and forth and more grounds will come out - meaning there was some left over. Spin the grinder and even more ground coffee from previous grinds will spill out even when the hopper is completely empty.
    Hence I find it much easier just to flush with each new shot if the grinder has been left unused for more than a couple of minutes.
    Oct 2009
    Geelong
    1,198
    Great advice! I myself measure out my beans, roughly put in 25 grams for the first double-shot, then 20ish grams for the next, then about 15 grams for the next. Isnt too much wastage at all, play around with measuring amounts! Doesnt take long either for those who think its too much fiddling around ;)
    10,496
    Quote Originally Posted by 7E61697A777276761B0 link=1269676092/2#2 date=1269682550
    Fair enough.
    I dont think you said what grinder you had.
    I recently sold my Sunbeam grinder but had pulled it apart many a time so know exactly what you mean.
    May 2008
    441
    Ezra,
    Theres also a trick people use for the Rancilio Rocky grinder where they get a slightly domed (soft-)plastic lid from Tupperware or similar, making sure it fits perfectly onto the grinder hopper, and use it to pump a bit of air through the grinder after every session - apparently it forces all the stuck grounds out quite efficiently. I havent heard this described for any other model of grinder but Im sure its perfectly possible to find the right sized plastic lid.
    But your method obviously works, too!
    Stuart.
    10,496
    Quote Originally Posted by 2F28293D2E283B2E3D32285C0 link=1269676092/5#5 date=1269719044
    A "click-clack" lid is the usual for a Rocky.
    I havent heard of anyone using a Tupperware lid.
    As for finding the right size, that might prove harder than you think.
    My Macap hopper is between click-clack sizes.
    But Ive developed a technique that works almost as well using the original lid if its the right type.
    [media]http://www.youtube.com/watch?v=mvmTGOuOryA[/media]
    Having sold my Sunbeam I cant remember what its lid looks like; I hadnt used it for quite some time before selling it and dont recall trying this method on it.
    See the original thread @ http://coffeesnobs.com.au/YaBB.pl?num=1263620858
    Jun 2009
    34
    Ive this attachment on my vacuum thats was never used, not sure what it was for, I think its an attachment to attach something else.. anyway, its perfect, its clean (goes through the dishwasher) I attach that to the end of my vacuum and suck the left over grinds out through the exit bit (damn I cant remember what its called
    Its not exactly perfect, but its fast, simple, effective and makes my vacuum smell like coffee hahaha, plus no part of the vacuum comes into contact with the grinder thats dirty..
    I know, I know, some people are probably giving me a funny look, but Im a neat/clean freak, plus the whole grinder gets wiped down with rubbing alcohol on a regular basis (like I said Im a clean freak heh)
    Oct 2009
    Geelong
    1,198
    I do the same lilTanker :) (apart from rubbing alcohol on the grinder). Its quick, easy, gets the job done!
    Coffee+carbon=heaven Mono's Avatar
    Aug 2009
    Regional Victoria
    760
    Quote Originally Posted by 7D787D45707F7A7463110 link=1269676092/7#7 date=1269736141
    Yep, I was doing the same until the wife complained about the stale coffee smell. Fortunately we also have a ducted vac system so now it gets used...................and presto, no more smell.
    Steve :)
    Jun 2009
    214
    Quote Originally Posted by 494E4F5B484E5D485B544E3A0 link=1269676092/5#5 date=1269719044
    Ezra,
    Stuart.
    yea i use this technique as well. It works just as well with your original hopper lit. Just flick it a few times like in thundergods video and that does the trick.
    I do this every time before placing beans for a shot. Works great. :P
    Apr 2008
    370
    Quote Originally Posted by 2E2B2E16232C292730420 link=1269676092/7#7 date=1269736141
    OCCCD
    Obsessive Compulsive Coffee CLeaning Disorder
    Vacuum cleaners? I salute you 8-)
    I had a laugh/
    Erm, ive given the lid flipping method a try. Doesnt really work with the EM0480... or maybe its my technique. Dont know, but for now ill still flush the burrs with beans.
  1. Freshness
    By philipmach in forum General Coffee Related...
    Last Post: 4th September 2012, 10:03 PM
  2. Coffee age and freshness
    By Barry_Duncan in forum General Coffee Related...
    Last Post: 20th April 2011, 06:50 PM
  3. Coffee Freshness
    By carloz in forum General Coffee Related...
    Last Post: 23rd November 2008, 09:08 PM
  4. Maximum and Optimum batch size for small BM?
    By NewToEspresso in forum Roasters
    Last Post: 10th May 2008, 01:48 PM
  5. Coffee Freshness at GJ
    By thegoodies in forum General Coffee Related...
    Last Post: 29th January 2008, 04:52 PM
