Results 1 to 5 of 5
Thread: Adjusting brew temperature to tune a shot flavour characteristics
    Jan 2007
    32
    Hi Everyone,
    Ive got a PID Silvia which I used to make about 3-4 double shots everyday. My source of green beans are from coffeesnobs of course. I bought a batch of Yunan Wet-hulled beans not too long ago and I am going through my first batch of beans through the Gene Cafe. I roasted it to a few snaps into second crack. These beans seem to be quite dense and need alot of heat to get to second crack.
    I am tasting a bit of bitterness from my shot. I tried dropping the PID temp to 107 deg instead of the usual 108 deg in an attempt to reduce the bitterness. It might have help a tiny bit but I cant be sure.
    My question is, how do you go about changing the brew temperature to achieve the optimum taste? I always read about how so and so will set the temperature to xx because of the blend they are using. What determines this temperature? A rough guide would be very helpful. Thanks in advance.
    Feb 2009
    73
    Re: Adjusting brew temperature to tune a shot flavour characteristics
    Hi Onewheel,
    I dont have a silvia, but ill have a go at answering anyway.
    First off 107 deg sounds a bit high. If you could flush the group head a little longer until the temp drops to around 95 and then lock in your portafilter this may help.
    A general guide to brew temp goes something like this - if the temp is too low the espresso will taste grassy and acidy and will most likely be sharp and have a rough mouthfeel. Too high and it will taste woody and possibly bitter, as well as being pretty flavourless.
    So the idea is to find a balance between the two which displays the coffees inherent characteristics.
    Also good to keep in mind that there is a relationship between grind - dose - and temperature. So make sure that your grind and dose are exactly the same each time your experimenting with different temps, otherwise you will drive yourself mad.
    Jan 2007
    32
    I might have to try this temperature thing again when I get a proper thermometer for the brew head. The temp is set to 107 instead of 90-96 degrees in account of heat loss through the water path.
    Hmm.. Relationship between grind, dose and temperature? Im screwed then. I adjust my grind daily and my beans change weekly. I was afraid this would open up more questions then answers. Thanks for the tip anyway :).
    17,218
    Welcome "onewheel"... [smiley=thumbsup.gif]
    Dont get too hung up on the "temperature" thing mate..... ;)
    Sure, you can tailor the Brew Temperature to extract the best from the bean, down to the nth degree. Best thing really, is to adjust the PID Setpoint to a value that delivers water at 92-93C to the top of the coffee puck. From what Ive read re: Silvias with PID Controllers fitted, this setpoint temperature should be around 107-108C when the feedback t/couple is mounted on top of the Boiler.
    If you do a search of the forum going back a year or two, there is quite a bit of information on how to do an accurate temperature measurement on top of the puck, if you dont own a Scace Device (not many of us do) and Id recommend you do that, just to be certain of what is happening with your particular controller installation.
    All the best... :)
    Jan 2007
    32
    Sounds good enough to me Mal. :)
  1. Adjusting the brew pressure (OPV) on Isomac Mondiale
    By hazbean in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 27th November 2014, 12:52 PM
  2. Adjusting Giotto Premium Brew Pressure
    By dumiya in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th November 2010, 10:43 AM
  3. Question Re Adjusting Brew Pressure
    By vicroamer in forum Brewing Equipment (non-machine specific)
    Last Post: 6th January 2009, 10:08 AM
