Results 1 to 13 of 13
Thread: Understanding Triple Shots
    Oct 2008
    124
    Hi there,
    I would like to understand some things about triple shots or, better said, a double shot with the amount of a triple. ::)
    - The more I increase the amount of coffee in the basket, more sourness (bad) I get. Im talking about from 15gr to 21. I thought that this is logical, because there is more coffee to extract for the same volume (a double) so the shot is underextracted, therefore I cant understand how you can pull good shots... :-?
    Tips please. Thanks.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Understanding Triple Shots
    Quote Originally Posted by 49524948260 link=1272652579/0#0 date=1272652579
    I would like to understand some things about triple shots or, better said, a double shot with the amount of a triple. *
    WTF... Why the Face ?
    To me a;
    A: Single is a single
    B: Double is a double
    C: Triple is a Triple
    D: Quad is four
    If some one gave me a "triple" and just used a double basket and ran for 90Sec I would be pissed >:(
    Oct 2008
    124
    Hehe. Because Im talking about pour 60ml (or a double ristretto) with 21gr instead of 90ml. No time change.
    10,496
    Because the water is travelling through more coffee it should take longer to pour; hence only 60ml in the same time.
    However, if you think it tastes under extracted then maybe you should make the grind finer to give it more time to extract.
    OR . . . maybe the sourness has to do with the water temperature.
    Senior Member Luke_G's Avatar
    Aug 2008
    Northen Rivers
    659
    From memory the La Spaz has 54mm baskets right?
    If thats the case like my DC then what had to do when i got my 21g basket is grind a little bit courser and overdose it more than the 16g basket and tamp a lot heavier.
    Owning the gear you do...i cant imagine you would buy or roast bad coffee so the other thing i can think of is maybe its the type your using?...is it a Kenyan or Zambian? or even a lightly roasted Indo?
    I must admit...i dont like using my triple basket...the taste quality just is not near the shots i can pull from my double.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    we use triple baskets at my work for every coffee that we make and run beautiful double ristretto shots over 50secs - but then again the machine has been set up with over sized heat exchangers and flow restrictors just for this purpose - so I would say that they type of equipment you are using will determine your ability to run the shot for longer
    interestingly we even inserted 0.6m flow restrictors at the group head of our second (spare) machine - an old Azkoyen Bravo which we stripped back and modded - and I would say that the Azkoyen pulls better espresso shots than the much more highly speckd BFC Synchro!
    Oct 2008
    124
    Thanks for the answers guys. :)
    Id like to know whats the theory behind the triple shots. I mean:
    Taking reference the italian standars of 7gr, 14gr and 21gr
    We have:
    Single shot - 7 gr - 25 sec - 30ml
    Double shot - 14gr - 25sec - 60ml
    Triple shot - 21gr - 25 sec? - But NOT 90ml; 60ml, the size of a double.
    And thats were I see the problem. If we cut the brew at 60ml, we would not doing an underextracted shot? :-?
    Quote Originally Posted by 774E505E647C3B0 link=1272652579/4#4 date=1272689234
    Owning the gear you do...i cant imagine you would buy or roast bad coffee so the other thing i can think of is maybe its the type your using?...is it a Kenyan orZambian? or even a lightly roasted Indo?
    Its 53mm.
    The type of bean affect the sourness yes, but overall I usually get sour shots. I use different beans... bolivia, colombia, sulawesi, etc.
    Quote Originally Posted by 5A48504F535E58545D5D5E5E5C4E423B0 link=1272652579/5#5 date=1272706750
    I have 6 sec. of mechanical preinfusion, so are you saying that we could try to pull a 56 sec. triple shot?? :o
    Im looking some recommendations of a roaster for their coffees. He say:
    Dose: 21-22g
    Brew Temperature: 202F/94.5C
    Brew Time: 28s-33s
    Total Volume: approx. 50ml
    Brew Ratio: 60-70%
    On a Synesso Hydra.
    What do you think, guys?
    Thanks for all.
    Oct 2006
    817
    the idea as I understand it is to run a double extraction from a triple shot as the basis for you coffees - to me this means a 30ml pour for a standard caffe latte and running the shot to a max 45ml for a 8oz takeaway coffee
    but times and mls are deceptive it also depends upon the beans that youre using, the age of the roast (ideally no more than two weeks post roast), the consistency of the grind, how much youre packing - and perhaps most importantly how the coffee is pouring - I tend to watch the shot and stop the extraction short if it starts to blond and / or dump the shot and start again from scratch if its running too fast or too slow
    not sure what a Synesso Hydra has to do with it unless you own the machine as Im sure that each machine is set up differently according to manufacturer specifications - then ideally it is modified to your own individual needs...
    Jul 2007
    2,286
    Oton,
    My "standard" shot is 20 grams of grounds, extracting about 20-25 ml of coffee in about 20 seconds.
    I gauge the stopping time by how pale the extraction is getting rather than the time or the volume. Im aiming for the above times/volumes but going by what I know gives me a great coffee in the cup.
    IMO the whole single/double/triple thing is a waste of time. Im dosing for the machine/basket combination and extracting for the taste I want. Everything else is secondary.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 5E6B7C7E4E766B7478757D190 link=1272652579/8#8 date=1272756107
    Thats what I do as well Greg
    I work within my machines tolerances
    And my taste buds are the winners
    I however dont pull triple shots any more
    10,496
    I also use about 20g in my "double" basket.
    I havent measured how many grams fit in my "triple".
    May 2007
    Perth, Western Australia
    3,156
    20g here too in my Synesso double (any more and my pf wont lock in), I watch the shot and stop pour at first sign of blonding
    Sep 2008
    759
    I think something people dont contemplate about updosing and triple shots is that the more coffee you stuff in to the basket, the lower the effective brew temperature is. Note, I do not mean the temperature the water comes out of the shower head, but the temperature at which the water passing through the bed of coffee is. This is because the coffee soaks up some of that temperature as it percolates. This would possibly translate in to shots with sour overtones
    Imagine this: a massive shot that contained 60 grams of coffee, supposing someone made a basket that deep, isnt going to just give you 90 mls of espresso in 90 seconds or so. There are diminishing returns. The waster passing through that puck is going to cool as it travels down. You would probably also find that the flow rate from the group head wouldnt be sufficient to support such a massive amount of espresso based percolation.
    Things dont just keep scaling up. Scott Raos book The Professional Baristas handbook does a good job of addressing this very issue.
    Personally Id be inclined to dose down a little more, perhaps even dare to run the shot a little longer. You never know, you might like it.
  1. triple filter for a pav pro
    By lumenary in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th April 2012, 01:46 PM
  2. My first triple blend
    By Ausnadian in forum Blending Room
    Last Post: 24th August 2011, 07:49 PM
  3. Priming, history, internal works and understanding
    By ush85 in forum Brewing Equipment (non-machine specific)
    Last Post: 13th June 2011, 03:17 PM
  4. Replies: 6
    Last Post: 2nd February 2009, 10:00 AM
