Results 1 to 8 of 8
Thread: Desacaling Help
    Apr 2010
    9
    Desacaling Help
    Hello fellow CS,
    I was after some recommendations as to what brand descaler and back flush cleaner I should be using. I am after something that will actually work and of course I want to buy from a sponsor. ;)
    I have a San Marino Lisa.
    Regards
    John
    Apr 2008
    Brisbane
    5,115
    Re: Desacaling Help
    Quote Originally Posted by 6F484E49627F485E5658493D0 link=1273645091/0#0 date=1273645091
    Hello fellow CS,
    I was after some recommendations as to what brand descaler and back flush cleaner I should be using. I am after something that will actually work and of course I want to buy from a sponsor. *;)
    Regards
    John
    Back Flush detergent
    I use Puly Caff back flush
    Cafetto is also good
    De scaler
    This is an acidic cleaner and can be dangerous
    If you are not confident in using it get the machine serviced by a sponsor
    May 2008
    4,196
    Re: Desacaling Help
    There is also the Clean Machine range. They provide a descaler as well as backflush. Check the sponsors listed at left.
    I agree that if you are not familiar with descaling, you are better paying to have someone do it for you. If you are not in the position to have someone do it for you, research well before trying it.
    Also, yours is a commerical machine, even if you use it domestically. I think there is are different products for commercial machines but Im venturing outside my sphere of knowledge here.
    Site Sponsor
    Aug 2006
    1
    Re: Desacaling Help
    John;
    Enclose list of some of the products:
    http://www.unpaid.com.au/products.asp?cid=42
    Regards
    Renzo
    Apr 2010
    9
    Re: Desacaling Help
    Hi guys, thank you for your prompt replies. Are the descalers advertised by our sponsor not safe to use or are these more for home machines?
    I currently have my machine apart for a thorough cleaning, although only 2yrs old it has been used lightly and I would like it spotless. So thought I would go over it with a tooth brush. Most piping I have pulled off and seems free of scaling. However inside the boiler and the heating element does show some light scaling.
    Should I be looking for a commercial descaling agent or will the ones from our sponsor do the job? Is there anywhere I can get some further info on descaling my machine? Any and all help will be greatly appreciated. I could send machine away, but I do like to do things myself and I already have the job started. ::)
    John
    Oct 2009
    Australia
    675
    Re: Desacaling Help
    If your doing a strip down I used Cafetto Vanish during my rebuild, you can get it from coffee parts, just make sure you follow the instructions. Drop your boiler or parts in to a bucket of it.
    Others have also had success with citric acid but I couldnt find it anywhere local and the vanish wasnt that expensive.
    If your doing regular descaling (ie not strip down stuff) I would recommend to use a proper descaler because it breaks down the chucks of scale rather than just falling off in sheets and getting stuck somewhere.
    Cafetto have a descaler, also I think Bombora have one Ive heard a few folk mention. Most site sponsors stock a decent descaler I should imagine.
    Apr 2010
    9
    Re: Desacaling Help
    Thanks Lacehim, Cafetto Vanish looks like the go. Do you happen to know which one of our sponsors retails it?
    Do you know what the Di Bartoli Clean machine solution is like? Again as he did respond to my post i would like to support him.
    John
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Desacaling Help
    Quote Originally Posted by 486F696E45586F79717F6E1A0 link=1273645091/6#6 date=1273668199
    John
    The vanish is from Coffee Parts and Clean Machine is good..
    I would go back to Di Bartoli and see what he / they can offer that is heavy duty and on par with the vanish...
    Different products for different uses..
