Results 1 to 12 of 12
Thread: grinds in my shots...
    Jun 2010
    41
    Hi Guys,
    New at this espresso game and still finding my way. I have just changed from a presurised basket to un presurised and now I am getting grinds in the shot is this normal? Its not a lot but enough to not quite finnish the very last of the coffee.
    Is this normal? If it is not then there os only things I can think of, my grind is too fine? but its at 15 on a sunbeam EM0480 which is at the coarse end of the scanle for espresso...
    The other thing is the unpresurised basked doesnt fit quite as snuggly as the presurised ones, its not so loose that it falls out when its upside down it falls out but its a bit loose would this be the issue?
    The espresso machine in question is a breville cafe roma...
    Or is there no issue and its just expected that there will be some grinds get thru...?
    Aug 2004
    2,312
    Re: grinds in my shots...
    Hello
    Ways for grinds to get into your cup:
    1) If you tamped your group handle on a surface with spilled grinds & some of the grinds stuck to the spouts (because the spouts were probably wet from the last coffee or from a wash).
    2) if the coffee filter (or "basket" if you do americanspeak) is cracked and grinds come through with the liquid. This happens with old filters that have suffered from a *lot of overpacking, and they eventually crack round the bottom "corner" where it is hard to see.
    3) If you have overpacked the filter and when you insert into the group, grinds are pushed out onto the sealing rim at the top, the group seal doesnt seal, & coffee (brew) leaks out over the top of the filter / group handle during brewing, and runs down the outside of the group handle and into your cups.
    4) same as 3) when the group seal is worn out / old / or buggered in some way!
    I think that about does it.
    OR maybe.....if as you say the new coffee filter that you bought is not a snug fit into the group handle, then again, you may have some leakage of grinds out of the top of the filter while you are brewing, and they find their way down into the cup as per 3) above.
    One of the above I should think, because grinds absolutely cannot get through the minute holes in the filters as the grinds are much bigger than the holes.
    Regardz,
    Attilio
    very first CS site SponSir.
    guv
    guv is offline
    Jan 2010
    111
    I had this problem with the krups basket on my breville machine. Dont know what machine you have but the result I had was the same.
    I stopped using it - cut out the bottom layer of the pressurised basket instead - better fit and no grinds.
    Andrew
    Jun 2010
    41
    Thanks guys, the machine is a breville cafe roma so I think the problem might be the same as you had andrew.
    How did you go about cutting the bottom layer of the pressurised basket out? seems like its frought with danger to me...
    thanks again.
    Nov 2006
    224
    I drilled out mine instead. Worked fine. Just dont go through both layers. Helped to have a drill press.
    guv
    guv is offline
    Jan 2010
    111
    Dremel or Drill it out - just be careful you dont go too far - there is only a few mils between the layers.
    Jun 2010
    41
    I actually took a dremel too it this afternoon, Ive gone within a whisker of too far I havent broken thru but I have weakened the material somewhat... is it imperitive to cut away enough so that every hole is exposed? I have cut about 20mm Diameter rough circle but I can probably get another 5mm from around the edges - theres still quite a few holes covered by the bottom layer...
    Thanks Again.
    guv
    guv is offline
    Jan 2010
    111
    Hi Callum
    dont have to expose all of the holes - as long as you open it up so that the extraction can flow through freely - a few cms across is fine.
    Andrew
    Jun 2010
    41
    Pulled the first shot from the modd filter and it went pretty well. So I dont think I damaged it too much. 1 hole looks a little elongated and the metal around there thin but so far so good!
    Now to strip my porta-filter... need to find a cheap holesaw so far they have been in the 50-60 dollar range... need to go to a big bunnies I think!
    JJJ
    JJJ is offline
    Jan 2010
    533
    Its definitely an issue with the Breville machines because i suffered through the exact same problem.
    Only a few more days until my Breville gets binned, and im be doing it with great glee.
    Jun 2010
    41
    Quote Originally Posted by 7F7F7F350 link=1276310181/9#9 date=1276668923
    mine is a problem with trying to use a krupps/sunbeam filter on the breville machine, the top rim is a different shape - no ridge on the sunbeam/krupps but there is on the breville... since modifying my breville basket by cutting away the bottom floor I havent had any grinds in the shot...
    Feb 2007
    242
    There is one other option for getting "grinds" in the cup, and thats simply that your group handle needs a good soaking in caffeto (or equivalent). If its been a while between washes, youll find that you get grit in the cup as the buildup of oils in the group handle cakes up & some washes through with each pour.
  1. Grinds
    By faemafamily in forum General Coffee Related...
    Last Post: 9th April 2011, 07:27 PM
  2. grinds
    By gavin in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 25th July 2008, 07:06 PM
  3. Do you get grinds in your shots?
    By ahxiongko in forum Grinders
    Last Post: 15th May 2008, 03:32 PM
  4. What do you do with your old grinds?
    By tempestv8 in forum General Coffee Related...
    Last Post: 12th April 2007, 09:49 AM
