Results 1 to 5 of 5
Thread: Double layer grind
    Jun 2010
    1
    Double layer grind
    Hi,
    I have stumbled onto something, just wondering if I am wacky or there are alike out there.
    Basically I fill 3/4 of fine ground coffee and 1/4 coarse one. *I smooth the fine layer with a fork before adding the 2nd coarse layer, AND tamp it real hard. *
    I get less channeling problem this way. *My theory is the coarse layer provides hundreds tiny passages to the fine layer so that water goes thru coffee evenly. * What do you think? * Thanks.
    Luke
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,247
    Re: Double layer grind
    Quote Originally Posted by 7E67797725677C75120 link=1276343733/0#0 date=1276343733
    Hi,
    Luke
    Sounds like a bit of stuffing around, what sort of Grinder and machine are you using, are your beans fresh, and what are the shots like?
    Has channelling been a problem? :)
    10,496
    Quote Originally Posted by 726B757B296B70791E0 link=1276343733/0#0 date=1276343733
    Yep.
    Just 1 more variable to go wrong.
    Jul 2007
    2,288
    So you would have some grounds being under extracted, and some over??
    Hows it taste?
    Oct 2009
    Geelong
    1,177
    Interesting idea though..... Hard to replicate, but interesting nevertheless...
  1. More questions- Grind size and single Vs double walled basket.
    By hellofellow in forum General Coffee Related...
    Last Post: 17th January 2013, 09:45 PM
  2. Grind differnce between single shot and double shot?
    By Wilki in forum General Coffee Related...
    Last Post: 9th April 2012, 12:57 PM
  3. Same grind no. for both single and double baskets?
    By dischucker in forum Brewing Equipment (non-machine specific)
    Last Post: 7th September 2006, 05:48 PM
