Results 1 to 6 of 6
Thread: Post pull dribble
    Jun 2010
    8
    Post pull dribble
    This is probably a silly and pedantic question, but Im curious so Ill ask anyway. And sorry about the title... I tried to resist... ::).
    Anyway, I currently own an EM5600, my previous machine was a Gaggia Carezza. On both machines, while steaming the milk (after pulling the shot), a "dribble" of coffee comes through the basket.
    Is this normal-ish or simply the consequence of owning low-end machines?
    In regards to achieving the "best shot" possible, should the "dribble" be discarded or included?
    thank you peoples
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Post pull dribble
    Quote Originally Posted by 76607F7D60707B6761120 link=1278619975/0#0 date=1278619975
    YES... And as to how the system works and your dosing levels..
    I would not ...
    But then your the only one that can decide if it makes the final result any better.. * It could be the best part of the shot *;) *But I doubt it.
    Jun 2010
    8
    Thanks AM...
    Quote Originally Posted by 052A23213609252A25232129212A30440 link=1278619975/1#1 date=1278628338
    Dosing levels... as in too much or too little?
    Ha! if youve tasted my coffee, it could be the best part *:P
    But... my non-pressurised baskets and grinder are due any day now... * :D
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 73657A7865757E6264170 link=1278619975/2#2 date=1278632608
    Hard to say... Gut feel.. Under dosing... But the only way to prove it is to try and then make teh call.
    Is the puk sloppy or nice and dry at present.. If dry and a slight shower screen imprint (SLIGHT), then just the machine and teh way it releases pressure or has a little blow back from teh steam side ?
    Jun 2010
    8
    Quote Originally Posted by 0B242D2F38072B242B2D2F272F243E4A0 link=1278619975/3#3 date=1278632882
    Is the puk sloppy or nice and dry at present..If dry and a slight shower screen imprint (SLIGHT), then just the machine and the way it releases pressure or has a little blow back from the steam side ?
    After the steaming, its nice and dry. But just after the pull, it is usually pretty sloppy. It was the same for the Gaggia.
    Jun 2010
    8
    Just thought Id post a quick update in case someone else has the same issue.
    Basically, after acquiring the non-pressurised basket and getting the grind right, the problem all but disappeared. Its a whole new coffee machine.
    Thanks to everyone for the advice here and elsewhere in the forums... *[smiley=thumbsup.gif]
  1. Pull shot.. great! Pull next shot.. whoooa waterfalls ahead!
    By simonsk8r in forum General Coffee Related...
    Last Post: 19th June 2010, 10:59 PM
  2. New beans / Cant pull a shot
    By JRCoffee in forum General Coffee Related...
    Last Post: 1st June 2010, 11:33 AM
  3. Macap pull down tamper
    By Micil_Knights in forum Brewing Equipment (non-machine specific)
    Last Post: 16th November 2009, 05:08 PM
  4. Best way to pull a single shot
    By stevenc in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th May 2009, 09:31 AM
