Results 1 to 14 of 14
Thread: Naked PF problem
    Jun 2010
    21
    Naked PF problem
    So I finally got my naked PF. I have been pulling great shots with my single basket (double spouted PF) since getting the machine so havenít changed what I was doing. If it ainít broke, donít fix it, right?
    Details:
    Grind= same as what I have been using for weeks with my single PF, though I did change bean. I thought it was the bean, so I went back to the old bean and still had the same problem.
    Dose=18gms (weighed)
    Tamp = perfect (shot starts from outside of basket screen and continues to middle)
    Channelling = none
    Colour= starts great. Tiger striping and then around the 10 sec mark BOOM! The Blonde Bomb Shell arrives. :(
    Taste = vial sour and sometimes bitter shots
    Crema = Extremely big/thick crema, though dissipates after a 30 sec in the cup to almost nothing. You can actually hear it foaming away like a coke! At the end of the shot I get a big Ghostbusters like air bubble that drops into the cup from PF (see around the 1:25 mark in this vid for an extreme over the top look at whats happening to me) http://www.youtube.com/watch?v=owBIzgLA6UQ
    Whats changed? Nothing except new naked PF and using my double basket instead.
    I have used 3 different types of bean with varying roast dates. All 5-10+ days old (so not too fresh) 1 blend has been in the freezer for a few weeks and this one performed the best.
    Itís quite obviously the fact that Iím now using the double basket and Iím not used to it. But after searching these forums and others Iím wondering if someone could shed some light with their experiences. Itís like Iím starting all over again. Frustrating and exciting at the same time.
    As of last night Iíve changed the grind setting too, but to no avail. But Iím thinking I need to play more in this area to get the desired result.
    Thanks in advance (once a pro home barista)
    Oct 2007
    790
    Re: Naked PF problem
    hey there,
    assuming youve played with the grind setting (to be a little coarser than you had set for the single), i would be inclined to say that perhaps its simply a dose problem. have u checked ur dose is not too high by locking your handle in and then straight out to see if theres any impression from the shower screen? the early blondign suggests that poss. your puck is being disturbed, hence early blonding.
    a vid of ur shot would be great.
    Jun 2010
    21
    Sounds like youre onto to something here. At one stage I did check that the puck wasnt coming into contact with the shower screen and it was. I then put less in, checked again and it had a slight impression from the nut on shower screen but it didnt break the puck. Is this still a problem?
    After fixing the dose issue I had it didnt really make that much difference TBH.
    May 2007
    302
    There will always be a variation when changing from single to double - might not be much, but it will be there.
    The other thing to try would be sticking your single basket into the naked PF because you have said that all was OK prior to the new PF and change to double.
    Take one of the 2 variations you have made out of the equation and see what happens.
    Another suggestion would be to go back to your single basket with double spout PF (your original configiration and make sure your coffee is as good as before, then go one variable at a time to find out where the problems are occurring.
    Jun 2010
    21
    Quote Originally Posted by 6358515E5E5F5E300 link=1280964656/3#3 date=1280978118
    Done this already. :(
    Thanks anyway.
    Oct 2007
    790
    hhmm,
    time for a backflush perhaps? or pulling out the shower screen for a good scrub?
    dirty showerscreen affects my shots for sure
    Jun 2010
    21
    So last night was another night spent in the kitchen practicing. The wife thinks I have a problem.... :o
    Anyway I adjusted the grind (finer) just by a touch. I learned just how sensitive the grind settings on the Mignon really are. I didnt give the little guy enough credit and this is where most of my problem was. Faith!
    I also adjusted the dose from 18g to 16g so as to clear the shower screen completely as I was just brushing the nut/screw before.
    So heres the vid as requested. I got the shot out at around 25sec, it tasted superb. But.....I had a bit of spatter around the cup (not good)...Tamp or grind?
    http://www.youtube.com/watch?v=D8YTiYxnq9I
    brett230873
    Quote Originally Posted by 7D584E555D52533C0 link=1280964656/6#6 date=1281053599
    Distribution was actually the cure for me wheh I had this issue.
    Jun 2010
    21
    ^^^^^Yeah well you are right there. I didnt think of that. But how can I distribute evenly if I have less coffee to in the PF to combat the puck touching the shower screen? *:(
    10,496
    Stir the grinds in the basket with a toothpick and tap to settle.
    If the mess around the cup is from channelling you need to get an even distribution to stop the channelling.
    Also try a nutating tamp.
    The video looked good so you must be close to getting it spot on.
    Mar 2008
    466
    Nutating tamp
    Jun 2010
    21
    Quote Originally Posted by 003C213A303126333B30540 link=1280964656/9#9 date=1281065212
    Yeah I have been doing the Weiss Distribution Technique since my first shot. Having said that, for this shot I used a knife because because I couldnt find my skewer anywhere!!!! ::)
    Aug 2010
    8
    Try filling the basket half way and give it a tap on the bench to settle the grind into the corners, then fill to the top and again tap on the bench. Cut the excess ground with a level blade (I use a sheet of Perspex) and tamp. I had a look at your extraction and it looks like you may be tamping inconsistently on the front left hand side (look for the darker tones). Try focus on an even tamp and you hopefully will get a better extraction.
    With regards to the foaming Ė what coffee beans are you using Ė Robusta blend? As Robusta generally has a higher CO2 content after roasting which will often give you a false height of crŤme, before it bursts and the level drops.
    May 2009
    268
    Sounds like stale coffee perhaps?
  1. which naked PF for GEE?
    By colinwen in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th September 2011, 09:17 AM
  2. Naked PF
    By kanda712 in forum Brewing Equipment (non-machine specific)
    Last Post: 20th June 2011, 10:15 PM
  3. Naked PF?
    By gattyguy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th January 2009, 02:02 PM
  4. Levettas Naked Problem
    By PhatBoy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd June 2008, 12:52 AM
  5. Naked or not?!
    By Zedd in forum Brewing Equipment (non-machine specific)
    Last Post: 18th July 2007, 09:08 AM
