Results 1 to 6 of 6
Thread: portafilter question on new machine
    Senior Member petar's Avatar
    Jul 2009
    122
    got a expobar minore iii on the weekend.. very exciting and caffeine fueled weekend..
    anyhow - when i put the portfilter in, its very tight and can only get it 7 oclock (if 6 oclock is 90 degree angle from the machine) - I have attached a pic..
    should i be worried?
    Apr 2008
    Brisbane
    5,113
    Re: portafilter question on new machine
    New machines need a little break in time
    The seal is bedding in & will soften with time
    Test it with a blind filter to see if its holding pressure without leaks
    If all is ok then use as normal
    16,881
    As per KK.... :)
    For example, my Diadema seals without leaks at around the same position and that is after 16 months of constant use. No need to lock-in the GH with the strength of Samson, it just needs to be firm. Excessive force will only serve to quickly wear out the Lugs and Bayonet of the Group, plus the Group Gasket.
    Its quite surprising how little force is actually required and KKs suggestion to test out using the Blind Basket is a great idea.... 8-)
    Dec 2004
    Earth!
    15,669
    As per the above as long as it seals properly alls well.
    Personally Id rather see the pfs lock at 7 oclock to 6 oclock rather than at 5 oclock. Ergonomically (For a right-handed person.) its easier on their body and I would think would lead to far fewer repetitive stress injurys. Why the industry hasnt adopted this is beyond me.
    Java "Manufacturers, are you listening?!?" phile
    Apr 2006
    4,126
    Quote Originally Posted by 4A6176617068696C65000 link=1281262863/3#3 date=1281297315
    They havent because theyre all actually designed by left handed people who are taking over the world one coffee machine at a time... :D ;D ;)
    Jul 2009
    122
    cheers for clearing that up for me.. didnt think i should force it into a 6 oclock position..
  1. 20 amp machine question
    By Daniel78 in forum Brewing Equipment (non-machine specific)
    Last Post: 17th November 2012, 04:21 PM
  2. Newbie - Machine Question
    By pbags in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st December 2011, 10:02 AM
  3. Sorry for the typical question... my first machine
    By Pablo in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 31st December 2009, 11:48 AM
  4. portafilter question
    By Wushoes in forum Brewing Equipment (non-machine specific)
    Last Post: 5th December 2006, 08:38 AM
