Results 1 to 14 of 14
Thread: Pour speed changes with constant dose and grind.
    Aug 2010
    5
    Hi,
    I have an automatic coffee machine. When I change to different beans from a different roaster the pour speed can change dramatically, even stopping the flow.
    I know that the grind and dose are constant, so what is it about the beans that changes the flow rate??
    Thanks.
    Jun 2008
    1,520
    Re: Pour speed changes with constant dose and grind.
    Hi Heading west
    lots of things change the pour just a few would be
    freshness, type of bean / blend, time of bay, humidity, roast depth (colour), storage used, even depends on your rate of use within the same bag of beans....
    when you change beans expect to change the grind
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 3B3632373A3D3424362027530 link=1281312134/0#0 date=1281312134
    AND
    Quote Originally Posted by 3E323B36363F530 link=1281312134/1#1 date=1281312806
    Hi Heading west
    Having just repaired two SUPER Autos... *I love the marketing...
    The beans actually grind into a pre dosing chamber; that what you do not have to wait as the grinds are always ready for use *::)
    Same as for manual dosers.. If ya fill it and then dont use it - the grinds will be stale..
    headingwest - Do some more reading as to Bean management.
    Supermarket beans are not always fresh..
    Rough guide as to a best before with correct storage:
    Green Beans / Unroasted *best B 4 *3 years
    Roasted Beans best B 4 3 weeks (kept in valve sealed bag)
    Ground Beans *best B 4 3 min
    So if ya changing beans and or from different suppliers and you may or may not have had a coffee or 3 for a while ..... Then you have to take all that into account.. As well as the Quality of the grinder...
    Then; I guess you leave the fresh beans in the bean hopper and top up every couple of days it means ya back to Stale beans...
    This is why; Great coffee is almost imposable *to find and Good coffee hard to find; while average / poor is the norm *:o
    Or is it that being a CS has raised the bar too high *:-/ :-/ :-/ :-/
    Aug 2010
    5
    Thanks all for the answers. I was hoping for something a bit more detailed. I already know that many things affect the pour and require a grind adjustment, but what about specifics.
    For example:
    Do fresher beans pour faster or slower?
    Which origins are slower and why?
    Will higher moisture content speed up or slow the pour?
    What about the roast level?
    Has anyone had specific observations about these things?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 737E7A7F72757C6C7E686F1B0 link=1281312134/3#3 date=1281392800
    For example:
    1: Do fresher beans pour faster or slower?
    2: Which origins are slower and why?
    3: Will higher moisture content speed up or slow the pour?
    4: What about the roast level?
    You have not given enough exact SPECIFIC details... *;D
    The issue is that there are 1001 variables -
    1: Define fresher
    2: Depends on how they were treated... And some behave very differenty to how you might have thought or what roaster was used...
    3: Depends on what level of moisture and as to the beans them selves as well as the impact the moisture might have on the grinder....
    Every thing you can think of; has variables that will affect the outcome. *Your dealing with a raw product and a whole lot of equipment; that all do things differently. *Further more, one little shift and it can have a significant impact on the cup *8-)
    That is what you will fine many here saying the same thing; be it in a slightly different manner..
    • 2 + 2 = 5 where 5 = great coffee
    • You can paint by number but you can not make coffee by numbers
    Thus if your a black and white person who wants a pure formula spelt out ( no greys)... *Not going to happen.
    Any number of rules of the thumb; but again lots of variables that have to be considered and nut assumed.
    Sep 2009
    82
    Just to answer one of your questions best i can,
    I have just started roasting my own and found that fresh beans (1-3 days old) do not seem to always pour faster or slower than older beans (1-2 weeks).
    Ive had fresh beans that ive had to use very coarse setting and fresh beans that required very fine settings.
    As AM said, there seems to be so many variables that i cannot say for sure if older or fresher pours slower or faster.
    Jul 2008
    Port Fairy
    2,993
    Quote Originally Posted by 6C6165606D6A6373617770040 link=1281312134/3#3 date=1281392800
    There is no general rule but some extreme examples are the Yemen BI that needs a fine grind and the Aussie MTE that needs a course one. Reasons are density and moisture. To be fair there is to many bean types out there and they all vary. Older beans generally need a slightly couser grind.
    Apart from that you will just need to feed the Auto the freshest beans you can, dont leave more than you need in the hopper at anyone time (helps maintain freshness) and adjust the grind as needed to try and get a decent shot out of it.
    10,496
    Quote Originally Posted by 07061306000A07630 link=1281312134/5#5 date=1281398643
    But were they both same beans? *;)
    I find that for any particular bean, fresher will start off pouring slower than when it has aged.
    As it gets older the grind needs to be finer.
    Different beans may have a different starting point but all will need to be ground finer as they age.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,889
    Quote Originally Posted by 5E627F646E6F786D656E0A0 link=1281312134/7#7 date=1281411838
    Different beans may have a different starting point but all will need to be ground finer as they age. *
    Nailed it in one TG, a mirror image of my experience. ;)
    Jul 2008
    Port Fairy
    2,993
    and as I get older my brain gets more mushy ;)
    Jun 2009
    Moonta SA.
    6,889
    Quote Originally Posted by 5651555A52584D5D5A53340 link=1281312134/9#9 date=1281415783
    and as I get older my brain gets more mushy *;)
    Probably early signs of old timers, most of us get a little wiser (course ya gotta have something there to start with) and a whole lot more cynical. ;)
    Aug 2004
    2,312
    To summarise:
    a) different supply = different roaster = different blends of beans & different methods of roasting using differing equipment and roasting profiles = different density of coffee = different amount of volatile oils = different amount of resistance in the puk = different rate of flow for a given amount of pressure.
    b) different age of beans / grinds for the same blend = different amount of volatile oils = different rate of flow.
    Which is why grinders are adjustable hehehe....so you can adjust down to slow the flow. ;)
    Volatile oils are not "real" oils...as the name infers they are volatile and go off into the atmosphere. The process of ageing / staling is the process of the volatiles going off into the atmosphere "piggy backing" on the CO2 gassing off. This means as the coffee ages, there is less oil in it = less resistance in the puk = quicker rate of flow.
    All of this is normal for fresh coffee.
    Stale coffee has effectively finished gassing off, has a much lower amount of volatile oils, & therefore has exhausted its beautiful aroma. But it is very "consistent" (there goes the C" word again) and requires much less adjusting of the grinder.....
    But try explaining all that to the "I know better than you" *espresso machine operators in cafes, that dont know how to adjust the grinder, and think that fresh coffee beans should be "consistent" :D
    Hope this helps.
    Regrdz,
    Attilio
    very first CS site sponsor.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 695D4A5C47706C4049494A4A2F0 link=1281312134/11#11 date=1281423297
    To summarise:
    a) different supply = different roaster = different blends of beans = different density of coffee = different amount of volatile oils = different amount of resistance in the puk = different rate of flow for a given amount of pressure.
    Hope this helps.
    Regrdz,
    Attilio
    Now that is a fancy of saying 2 + 2 = 5
    AND it makes perfect sense to me except for the following;
    I had a laugh I thought ya just used a bigger tamper or used a bigger Barista to stomp on it :D ;D ;)
    (Joshing of course - my bitter antisocial side showing)
    16,881
    Quote Originally Posted by 1C203D262C2D3A2F272C480 link=1281312134/7#7 date=1281411838
    Mirrors my experience too TG, in a general kind of way.... ;)
  1. Argh!! Constant under extraction.....
    By Cinders in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th March 2014, 04:52 PM
  2. Roast/Grind/Dose Variables
    By jaffa777 in forum General Coffee Related...
    Last Post: 23rd July 2012, 07:49 PM
  3. Sunbeam EM6910 constant humming noise
    By arch4nge1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th April 2011, 09:13 AM
  4. Fine grind quick pour
    By Quomby in forum Grinders
    Last Post: 6th August 2010, 07:07 PM
