Results 1 to 4 of 4
Thread: Grease
    Feb 2010
    148
    Grease
    My steam knob on my Giotto is squeaking. Is there a particular kind of grease I need to buy and any recommendations where I might get it?
    Thanks, in advance...
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Grease
    Quote Originally Posted by 313437222233243A332F560 link=1298463730/0#0 date=1298463730
    bunnings or J-car = "inox "* food grade been posted a dozen times* :o
    Oct 2008
    505
    Re: Grease
    I use INOX MX6.
    http://www.unpaid.com.au/product/Food_Grade_Machinery_Premium_Grease
    Food grade and doesnt melt.
    Some Repco stores also stock it.
    Aug 2010
    371
    Re: Grease
    Depends on the actual location of the squeak - if the thread in the tap is exposed to the steam when the tap is open, use Inox. If its external to the tap (where the knob screws in/out on the body of the tap and pushes or pulls a plunger) or has a seal or O-ring between the shaft thread and the internals of the tap, use a copper anti-seize compound. The anti-seize keeps the threads lubed much longer than the Inox does, but isnt food-grade so has to be kept away from the steam passages in the tap.
  1. Where to buy food grade grease
    By tintub in forum General Coffee Related...
    Last Post: 26th November 2018, 01:55 PM
  2. E61 machines and grease.
    By Yelta in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th March 2013, 01:06 PM
  3. Cleaned mazzer - question about grease
    By guv in forum Grinders
    Last Post: 14th June 2010, 05:31 AM
