Results 1 to 5 of 5
Thread: what am I doing wrong?
    Apr 2011
    152
    I bought a new breville smart grinder last week and have been very impressed with the improvement I am getting in my shots since, noticably better with a better crema but every now and then I will get one really good shot and the next one is very acidic in taste, I always do 2 at a time (one for the mrs and one for myself) and usually the second one is not as good as the first. Is there a way to tell what i am doing wrong buy the taste?
    Jun 2010
    217
    Re: what am I doing wrong?
    what machine are you using?, why not use a double basket and do two at once
    maybe you need to let it warm up more between shots.
    need more about your coffee maker, dont think the grinder is at fault.
    Apr 2011
    152
    I am using a Saeco V V. I seem to think temp might have something to do with it as the Mrs sometimes comments the shot is much hotter than the last. I always use a double basket in an unpressurised PF and fill to top then double tap then fill again, double tap, even of with the side of my palm then do a firm tamp and seal. I end up with about 18 grams of coffee and always do double shots. More often than not its a good shot its just sometimes I get the occasional one that is very acidic.
    May 2007
    440
    The temperature is definitely the culprit here. As the boiler is quite small, it takes a while to reach optimum temp. Just give it a few extra minutes.
    Nov 2010
    Melbourne, VIC
    185
    Quote Originally Posted by 0308031B100D5755620 link=1307281339/3#3 date=1307341333
    Yeah, this is generally what I find when pulling back to back shots. I generally wait around 3 minutes before pulling the next one.
  1. What went wrong?!?!
    By fauzigarib in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 13th February 2012, 10:53 PM
  2. What could be wrong ?
    By blaggon in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2012, 08:47 AM
  3. What am I doing wrong?
    By RobatFarrer in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th December 2010, 09:53 PM
  4. What am I doing wrong???
    By thomm0 in forum Milk Froth and Bubbles
    Last Post: 17th July 2008, 09:10 AM
  5. What can wrong will
    By Stan in forum Roasters
    Last Post: 14th June 2008, 08:38 PM
