Results 1 to 3 of 3
Thread: Water Filters and Lime Scale
    Gum
    Gum is offline
    Jun 2011
    17
    These pages and many other web sites emphasise the virtues of filtering your tap water.
    What I am not so clear on is what degree of success the various water filters have on reducing/eliminating lime scale build-up.
    We use a Doulton on-bench ceramic filter. I have no doubt that it is cleaning our water significantly but is it doing anything to reduce lime scale build-up?
    Aug 2004
    2,312
    Re: Water Filters and Lime Scale
    In a nutshell......
    The elements that come out of solution as scale inside your coffee machine, pass straight through "regular" particle filters because they are not particles......they are "in solution".
    There are two ways of attacking this:
    a) use a "water softener" which is a device that takes the elements out of the water before the water goes into your machine and
    b) use a "water filter" that releases a scale inhibiting substance that stops the elements coming out of solution as scale in the machine and/or sticking to the insides of the machine.
    If you want to know if your water filter has scale inhibiting properies, you will have to make enquiries with the supplier / importer / manufacturer of your filter.
    Hope that helps.
    Rgdz,
    Attilio
    very first CS site sponsor*
    Caffeine Junky
    May 2009
    1,103
    You also need to consider your input water and if you actually need a scale inhibiting filter or water softener.
    I live in Adelaide so am obsessed with monitoring water hardness. If youre in Melbourne you may not need to bother.
    Hardness test strips are readily & cheaply available from many of our fine sponsors or you should also be able to get them from a pool supply shop.
  1. Pure Water water filters
    By chrislng in forum General Coffee Related...
    Last Post: 18th December 2012, 06:34 PM
  2. scale deposits in my water- Gaggia coffee deluxe
    By kierent in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd May 2012, 11:41 AM
  3. Water treatment - Scale inhibitor Vs. water softner
    By prloring in forum General Coffee Related...
    Last Post: 11th February 2012, 09:04 AM
