Results 1 to 6 of 6
Thread: Long Black hot water question
    Jun 2011
    4
    Hi there
    I have been pouring a few decent long blacks on my Gaggia Classic. Im wondering the best way to add hot water first, then add the espresso shots. I am currently grinding beans, put cup under brew head and run hot water. It works fine but I get little bits of coffee beans in the water (even after running brew head for 20 seconds). If I take the hot water from the tap, its too cold for me, if I take it from the kettle, it might burn the coffee mightnt it?
    Your thoughts would be mucho appreciated.
    Anthony
    Jul 2008
    Port Fairy
    2,993
    Re: Long Black hot water question
    On a commercial machine with a hot water spout I pour about 4 oz into a cup then grind/dose/tamp. The theory is that then the cup will have dropped the temp of the water down below the point where the coffee will burn on contact. Then pour the shot.
    So with the Gaggia boil the kettle leave it for a touch before pouring into the cup then prep your shot and pour.
    Rough guide anyway* :)
    16,957
    Quote Originally Posted by 2F282C232B213424232A4D0 link=1310521849/1#1 date=1310522315
    This works well for me too. No matter what machine is living with me at the time... ;) 8-)
    Jun 2011
    52
    you could always put the portafilter in without grinds, then pull the water, then add grinds and your shot, but youll likely drop the machine down below brew temp, so a kettle is probably best.
    150
    On the classic you can get water from the boiler.
    If you press the brew switch and the steam switch at the same time, while opening the steam valve - you will get clean hot water from the boiler through the steam arm.* Easy.
    Personally I like only a little water (maybe 60ml) and to let my water cool for a few minutes so I can drink it straight away. No point watching your crema dissipate while while you wait untill the temp is drinkable.
    Jun 2011
    4
    Thanks people, will try the kettle and steam arm.
  1. Long black
    By kike10 in forum General Coffee Related...
    Last Post: 24th January 2013, 09:16 PM
  2. amount of water in a long black
    By ironically_named in forum General Coffee Related...
    Last Post: 23rd March 2011, 02:55 PM
  3. Long Black?
    By stevenkylie in forum General Coffee Related...
    Last Post: 19th July 2007, 02:46 PM
  4. What is a long black ?
    By Brendan in forum General Coffee Related...
    Last Post: 12th July 2007, 05:48 PM
