Results 1 to 6 of 6
Thread: Beans impact on espresso length
    Jun 2011
    4
    Quick question, I have bought the variety (4) pack of roasted beans from Beanbay. Made an Ethiopian bean espresso which was great, 25 sec, perfect pour, etc.. Have tried both the PNG and Sumatran beans and these poured in 15 secs. They both still tasted ok, not great. I had the same grind, dose, tap, tamp pressure. Do beans make a 10 sec difference to the pour? Should I be changing the grind for different beans? I thought the prep was very similar, obviously not identical.
    Anthony
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Beans impact on espresso length
    Quote Originally Posted by 060D17000E07103D03620 link=1310603183/0#0 date=1310603183
    Sure can, maybe more
    Most likely you will have to, you may find two beans that are very similar though.
    Thats the aim, have everything the same and only adjust the grind to get the results you want.
    Jun 2011
    297
    its been discussed in this thread
    http://coffeesnobs.com.au/YaBB.pl?num=1280017936
    the ethiopian needs a coarser grind* :)
    I think the experienced can get the grind right in 2 or 3 trys but we mortals may take longer.
    I also have a pack so I looked for the reviews 8-)
    Jun 2011
    4
    Thanks guys, maketh sense.
    Think my ethiopian was spot on grind then, my other beans then need a finer grind (currently at 15 secs).
    Thanks heaps :)
    Jul 2004
    2,121
    Yeah - I had the same thing last night.
    Finished off my Bali and cracked open some Ethiopian Gambella and ended up needing a 6 click adjustment coarser before getting a good pour.
    Probably the biggest change I have had between beans.
    Brett.
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,085
    I find that there is only a small variation needed in grinder setting from bean to bean. On my Rocky most beans grind at 8 for the double basket and 7 for the single. A short pour is the sign to go a click finer on the grinder. That one click can make a big difference in the length and quality of the pour. I occasionally need a two click variation, but that is rare. I actually find my biggest challenge is consistency in the tamp & dose. A small variation makes a lot of difference. Then there is the temperature difference from shot to shot as the machine gets hotter. Hey this is complicated isnt it!
  1. Beans Beans Beans French Press, Filter or Espresso
    By summercrema in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th January 2011, 08:56 PM
  2. Length of coffe shot
    By Barwongirl in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th May 2009, 09:05 AM
  3. length of beans in grinder?
    By baz8485 in forum General Coffee Related...
    Last Post: 2nd April 2009, 08:07 AM
  4. Impact of ambient temperature
    By Myrtle in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 14th December 2006, 05:02 PM
  5. length of pour - 45 second
    By pharmaboy in forum General Coffee Related...
    Last Post: 12th June 2006, 01:51 PM
