Results 1 to 5 of 5
Thread: filtered or unfiltered water??
    Dec 2010
    9
    Gday CSs
    question, I am awaiting the arrival of my new giotto evoluzione, from my understanding using unfiltered water eventually leads to corrossion internally in the machine. If i choose to use unfiltered water in the mean time whats the best maintance practice to avoid the internals from corroding?
    cheers
    Mar 2011
    46
    Re: filtered or unfiltered water??
    I cant give you any advice on the maintenance of your Giotto, but you could buy properly filtered and guaranteed non-corrosive water instead. Im using Nobles Pureau for all my tea and coffee needs and at 70 cents per litre from the supermarket I wouldnt even think of operating and maintaining my own filtration plant.
    Steffen.
    Oct 2006
    504
    probably not corrosion you should be worried about, more so the lime scale
    I dont have a giotto myself but I use one of the brita jugs and have only had to descale my machine once so far
    depends how hard your water is in the end
    Gum
    Gum is offline
    Jun 2011
    17
    I had similar concerns, more about lime scale than corrosion. I bought a sink top water filter which installed in about one minute and I believe filters well enough to protect your lovely machine.
    The brand I bought is Doulton. Looks good as is made from polished stainless steel and the internal filter is ceramic. Cost around $170. Weve had it about three months and, so far, are very happy with it.
    Jun 2011
    290
    Hey Notis this is what I use with my evo.
    It is from Bombora and uses a combination filter/softener. Note! some dont have softening properties which is basically why you are filtering the water.
    I installed it in about 2min in the laundry and just run it into a Brita jug and fill.
  1. Filtered Water, what do you use?
    By coffee_snob in forum General Coffee Related...
    Last Post: 31st May 2009, 08:40 PM
  2. Filtered Water
    By Ren in forum General Coffee Related...
    Last Post: 11th September 2006, 10:07 AM
  3. filtered water
    By mr_fox in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2006, 05:22 PM
