Results 1 to 9 of 9
Thread: Coffee pouring too thin
    Feb 2009
    63
    OK, I used to get a nice thick pour / shot. Honey like. It now is thick for about 4 seconds then just runs thin and looses it rich brown toffee colours.
    Ive tried different brands of coffee but doesnt seem to make a difference. Ive tried different tamping and grinds but cant get it right.
    Ive never been one to be able to describe tastes but I do know that it doesnt taste right. My ristrettos used to be amazing. No more.
    Ive cleaned the machine through a couple of times now and the water still seems very hot so I know the boilers working.
    Any suggestions on how I go about fixing my poor shots?
    14,665
    Re: Coffee pouring too thin
    Quote Originally Posted by 606277606B2E3131030 link=1316902908/0#0 date=1316902908
    "Brands" sounds concerning. If it wasnt roasted within the last few weeks, its most likely beyond peak. What combo of machine/grinder/coffee are you using catch-22?
    Feb 2009
    63
    Yeah brands might be the wrong word to use.
    My favourite is Espresso WOW. Just bought another Kilo last week. I always use fresh beans. Which takes me to another observation I missed on the original post.
    When I get my fresh beans, for the first couple of days the pours are bubbly and not as thick as they get after three to four days. This is the gas I know but I didnt see this on the last few batches.
    My grinder is a Rocky.
    Jul 2007
    2,286
    Unfortunately, if neither your beans nor your machines have changed, the most likely explanation is the nut behind the portafilter.
    Try going back to the start with your technique and see what happens. If that doesnt work then maybe your machine(s) have changed, and will need to be serviced.
    Feb 2009
    63
    Will blow the dust off of the old coffee school book and give it a go....
    150
    What machine??? It may be a pump problem?* Have you had to go dramatically coarser?
    NMB
    NMB is offline
    Jul 2011
    9
    Have you pulled apart and cleaned your grinder?
    Sep 2011
    Canberra
    145
    Quote Originally Posted by 090A05470 link=1316902908/6#6 date=1317179403
    I was just reading through some old posts and found someone with a rocky grinder who after replacing the burrs could not get a good grind any more, even with the grinder set one notch above the point where the burrs began to touch.
    They found that by putting some teflon plumbers tape on the thread it kept the hopper end more stable and produced a better grind.
    Perhaps if you have cleaned the grinder, the hopper may be vibrating a little, causing the burrs to grind the beans unevenly, and some teflon tape may help.
    Note: I have a rocky grinder too, but I havent done this. Do a google search for "rocky teflon mod" for more info.
    NMB
    NMB is offline
    Jul 2011
    9
    I was have a simular problem with my challenger. I found that there was heavy build up inside the grinder between the bottom burr and the casing. After I cleaned it out the shots returned to rich colour and viscosity.
  1. 'Thin' tasting coffees since upgrading from Gaggia Classic to Silvia
    By greenplastic in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd July 2012, 06:42 PM
  2. EM5900 thin espresso
    By Bames in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 2nd October 2011, 05:18 PM
  3. My steamed milk is too thin....help
    By Dragonlord in forum Milk Froth and Bubbles
    Last Post: 30th December 2008, 10:29 AM
  4. Pouring Technique
    By Stew in forum Milk Froth and Bubbles
    Last Post: 27th June 2007, 08:11 PM
  5. latte art pouring problem
    By dsc in forum Milk Froth and Bubbles
    Last Post: 9th June 2007, 07:57 PM
