Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Dimal
Thread: Hazelnut coffee
    Nov 2009
    Altona, Melbourne
    1,578
    Hazelnut coffee
    I wasnt sure if this should go in grinders or this section as Im not quite sure where I am going wrong.
    Do you need a specific grinder to make Hazelnut coffee or is it the ratio of hazelnuts to coffee beans that makes the difference?
    Ive tried a couple of different ratios of hazelnuts and coffee beans and all I get is a paste not unlike caffeinated peanut butter. It takes some time to clean the grinder so I thought I would save time by asking how everyone else does it.
    I am currently using a K3 WBC, would a doserless grinder or a larger grinder make a difference, or is it purely a ratio of beans to nuts thing?
    I am assuming I need to "up" dose as the hazelnuts displace some of the coffee in the basket, yeah?
    Ta in advance 8-)
    Senior Member Pavoniboy's Avatar
    Jan 2009
    Minnamurra NSW
    693
    Re: Hazelnut coffee
    Are you serious?
    Did you really put hazelnuts through your Compak?
    Sep 2011
    395
    Re: Hazelnut coffee
    Youre Serious about putting Hazelnuts through your coffee grinder?* :o Oh dear lords...
    I wouldnt put Hazelnuts through a coffee grinder, They have way too much moisture to really work all that well with a burr grinder
    using a smashy-wirly-blade-of-doom type grinder is a better option...
    Or a Mortar and Pestle...
    Using a coffee grinder only causes... Problems.* :-X
    Member Angusw15's Avatar
    Oct 2011
    50
    Re: Hazelnut coffee
    +1. I wouldnt use your best grinder to make a hazlenut flavour. Perhaps buy a cheap second hand one first and use that one so that your daily cup can remain top quality. ;)
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    Quote Originally Posted by 4D60746669686F66407547607564010 link=1322010691/2#2 date=1322012554
    Would conical burrs be better of flat burrs? Id like to grind them together because once I get the quantities right then I can roast them together as well.
    Jan 2009
    Minnamurra NSW
    693
    Re: Hazelnut coffee
    You do realise its not 1st April?
    Aug 2011
    116
    Re: Hazelnut coffee
    Trenski, i suggest you also add Tea leaves to the mix to make use of the energy you are consuming to perform the roast.
    These could later be removed delicately by hand post roast ready for brewing.
    You never know, as a bonus the tea may take on a lovely coffee flavour!
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    There could be merit to that timmyb, Ill have to get some tea leaves before they have been cut up or else it will be too hard to separate them from the chaff.
    I wonder if I could dry some Bay leaves from the tree outside at the same time.
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    Quote Originally Posted by 0031263F3E39323F29500 link=1322010691/1#1 date=1322011836
    Are you serious?
    You would think I had learnt, back in 2007 I had a similar problem I posted about on CoffeeGeek, heres a snippet
    on the radio comes an advertisement for a certain cafe within a fast food restuarant, sounds really nice, playground for the kids, range of beverages including one I hadnt heard of before....
    A Banana and Toffee flavoured coffee, a banoffee coffee (my name, might have to trademark it later).
    So I got some bananas and some toffee. Put the toffee in the cup so the espresso would melt it and poured my shot, it was very slow and really clogged my machine even though I had ground it quite course.
    I went to make another shot and this is where I ran into trouble and need some advice.
    How do I clean the banana out of the grinder?
    Dec 2004
    Earth!
    15,465
    Re: Hazelnut coffee
    Flavored coffees are made with liquid extracts that are sprayed on/added to the beans post roasting.
    Java "Not in my grinder thanks!" phile
    Jan 2009
    162
    Re: Hazelnut coffee
    Trentski, you must be bored, but you did get some bites ::)
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    Quote Originally Posted by 153E293E2F3736333A5F0 link=1322010691/9#9 date=1322023925
    Thanks JP but Im after something more authentic.
    I had to give up on the banoffee after we had a couple of cyclones and the banana price went through the roof, so nut flavoured coffee it was.
    I wont even start talking about the Irish Moss flavoured coffee :( surely someone was taking the piss when they made that up
    Dec 2004
    Earth!
    15,465
    Re: Hazelnut coffee
    Quote Originally Posted by 6E687F746E6971731A0 link=1322010691/11#11 date=1322027152
    You could always go to Hawaii and get some of the Kona with Macadamia nuts coffee they sell to the tourists there. It has actual Macadamia nuts in with the beans.
    ;D
    Java "Pass!" phile
    May 2010
    Sydney North Shore
    1,325
    Re: Hazelnut coffee
    I believe that flavoured coffee is for those who dont like the taste of coffee. Also it is a way of using up poor quality and stale coffee.
    Barry
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    Quote Originally Posted by 1F3C2F2F24021928333E3C335D0 link=1322010691/13#13 date=1322084195
    You could say that about any beverage. I believe orange juice is for those who dont like the taste of coffee ::)
    Its the old saying "It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt"
    Jul 2004
    2,121
    Re: Hazelnut coffee
    Quote Originally Posted by 2E283F342E2931335A0 link=1322010691/14#14 date=1322086503
    And yet, you started this thread!
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    What thread? you havent linked to one
    Aug 2011
    116
    Re: Hazelnut coffee
    Quote Originally Posted by 262134222F391F71797979400 link=1322010691/15#15 date=1322092628
    Key word being THIS
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    Quote Originally Posted by 14090D0D1902600 link=1322010691/17#17 date=1322113229
    Key word being THIS
    nah, your links still not working
    Jul 2004
    2,121
    Re: Hazelnut coffee
    Quote Originally Posted by 1711060D1710080A630 link=1322010691/18#18 date=1322113814
    Key word being THIS
    Hmmm ... yes, you certainly are removing all doubt!
    Nov 2009
    Altona, Melbourne
    1,578
    Re: Hazelnut coffee
    pffft it was a fun thread until the haters rolled in
    Mar 2004
    Internet
    16,685
    Blog Entries
    1
    Re: Hazelnut coffee
    Roasted coffee will absorb smells around it.
    Have you tried bagging fresh roasted hazelnuts and fresh roasted coffee together while the coffee rests?
    You would then remove the nuts before grinding.
    For fun you could also do blue cheese and onion in a bag of coffee, just the thing for coffee at a BBQ.
    8-)
  23. #23
    16,689
    Re: Hazelnut coffee
    Bloody hell you guys.... :o ;D ;D ;D
    I just spat a freshly made brew all over my screen and keyboard. This thread should be moved to the Humour section.... :P
    Icecursor likes this.
  1. Hazelnut flavoured coffee beans
    By snoblet in forum General Coffee Related...
    Last Post: 9th July 2011, 09:15 PM
