Results 1 to 5 of 5
Thread: Inconsistant shots using different beans?
    Oct 2011
    56
    I wonder if anyone on here can tell me why I get different shots with different beans. I generally use 2 different beans for my coffee, but I find that I need a finer grind for one than the other. Is it because one has more oil or is one stale etc. PS I use the same tamping pressure on both.
    I find if I use the same grind setting on both one will take approx. 30 seconds and the other about 15 seconds??? :-[
    14,665
    Re: Inconsistant shots using different beans?
    Quote Originally Posted by 2F3D3530332E5C0 link=1322716171/0#0 date=1322716171
    Gday Sailor. Yes- all of the above can have an influence. You can add temperature, humidity and whether your tongue is pointing left or right to your list (and probably a host of other things) as well ;)
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    946
    Every bean is different. After they have been roasted I find I am adjusting the grind about 3 times for each bean as it ages. It normally takes me about 7 days to go through 500g of roasted beans so about every 2 days I find I need to adjust the grind. As Chris stated humidity, type of bean, temerature all affect the grind
    Senior Member summercrema's Avatar
    Mar 2008
    266
    Something I can think of is the density of the bean among other things.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    each bean has its own unique grind point which if not different from any other then at least requires constant attention - and even the same bean can vary 20 or more times during the space of a day
    and as a general rule the more a bean ages the more it gushes so a wider grind for newer beans and a finer grind setting as the bean ages is the order of the day...
  1. Beans Beans Beans French Press, Filter or Espresso
    By summercrema in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th January 2011, 07:56 PM
  2. Problems with shots, or is it just the beans?
    By emckissock in forum General Coffee Related...
    Last Post: 3rd December 2010, 04:35 PM
  3. Pulling shots with freshly roasted beans.
    By Yelta in forum General Coffee Related...
    Last Post: 15th May 2010, 02:40 PM
  4. Opinions wanted: beans for shots vs Milk based coffees
    By chipotlemuncher in forum General Coffee Related...
    Last Post: 25th July 2009, 07:01 PM
