Results 1 to 4 of 4
Thread: C150 water filter kit - installation
    Jul 2004
    2,133
    I recently decided it was time to act on a water filter kit and purchased the C150.
    It arrived as a bag of parts with no instructions.
    I have sent a note to Bombora (Fridge Filters) today asking for assistance, but as it is a Sunday and I am keen to try and complete this today, I thought I would see if anyone who has been through this could help.
    Basically, the part I am stuck on is how to connect the mains water to the system. Further to that, if I want to keep our existing cold water tap, do I need to go and buy a T connector to allow this?
    I can provide pics if needed.
    Anyone able to help?
    Cheers.
    Brett.
    14,666
    Re: C150 water filter kit - installation
    Hi Brett,
    There are a few different kits and it depends on which you have.
    I think it should look something like 1/2" male cold outlet>PLV>Filter>3/8-1/4Reducer>(t-piece to machine if plumbing in)>Supplied additional sink tap.
    Hope that helps ;)
    Jul 2004
    2,133
    Chris,
    Yep - that helps. Thanks.
    I will head off to the hardware store with various parts in my pocket to see if I can get the right kind of connector.
    The new tap is in place, the spot for the filter under the sink is clear, the poly tubes are nearly all connected. Just need to get the last part done and I think Im there.
    Brett.
    Jul 2004
    2,133
    Well, no joy Im afraid.
    Once again I am proving that as a plumber, Im a good IT consultant.
    Found the required pieces to make the junction. Seemed to tape it all up OK, but I think Im missing something with the connection to the filter. The pressure in and out seems too high and there were leaks in a few places.
    I have some bits over in the bag and I am unsure if any of them are meant to be in place somewhere to help reduce the flow rate.
    I have reverted the connections to original for now and will have another go at it once I have a chat with Bombora.
    Oh well - time to roast coffee now.
    Brett.
  1. Brita C150 filter bypass setting
    By ogip in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 6th November 2012, 09:00 PM
  2. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  3. Water Filter
    By tojo1 in forum General Coffee Related...
    Last Post: 22nd April 2009, 06:31 PM
  4. FS Water Filter
    By Koffee_Kosmo in forum SOLD
    Last Post: 24th May 2008, 03:49 PM
