Results 1 to 10 of 10
Thread: Cloudy latte glasses
    Nov 2004
    Augustine Heights QLD
    302
    Being a time challenged person, I have frequently used the dishwasher (that would be the electrical automatic version) to wash my latte glasses. Recently they have started to go cloudy. I believe this to be a residual calcium scale deposit from the water baked on during the rinse and drying phase of the machine cycle. I reside in Werribee, so who knows whats in the water.
    So how do I get rid of it. Will it be as simple as washing in citric acid? Has anyone seen and resolved this type of thing before. And, yes, I am too tight to go buy new glasses.
    Aug 2004
    125
    Re: Cloudy latte glasses
    Try throwing them into a bucket of hot water with about 1 tablespoon of nappysan added and leave it overnight.
    Nappysan is good stuff. I use it to clean my showerscreens, portafilters (minus the handle) and baskets.
    Make sure you rinse well with clean water and use gloves when sticking your hand in the bucket. Your hands burn and itch like hell otherwise. :o
    Warren -
    admin
    CLR would probably work too.
    Rich
    Apr 2004
    327
    CLR contains Hydrochloric acid, Hydrochloric acid was used on our Boema to strip any rubish from it when we first got it and then rinced well. Id say the CLR will work just as well, But the Napisan too is fantastic stuff as well......
    I heard that sometimes the detergents used in Dishwashers also eats at the glass as well, but I might have been mistaken.
    FB :)
    Aug 2004
    125
    Quote Originally Posted by FrenchBean link=1101786555/0#3 date=1101859830
    FB :)
    Yes, they can etch glass if theyre not thoroughly rinsed off or the rinse aid in the dishwasher is not working properly. If youve ever noticed painted glasses, the paint fades gradually with repeated applications of dishwashing powder.
    From memory they contain varying amounts of alkaline salts which is pretty nasty stuff. Its like a milder form of caustic soda or "Draino". So very thorough rinsing is probably a good thing.
    Warren -
    Nov 2004
    6
    You could also try bicarb. Just pour a little into your glass and wipe it inside and out with a sponge/cloth. It doesnt stink like bleach and its eco friendly.
    Nov 2004
    302
    During the week I tried the 48 hour soak in Nappysan. I would say it was a 25% effective. Then the 48 hour soak in vasalene(sp?), again about a 10% change. Ill move on to citric acid and then bi carb soda this weekend.
    Aug 2004
    125
    Boris,
    If you use Nappysan make sure the water is fairly hot. Not boiling but as close as you can get (espresso temps ;) ). Always seems to be more effective this way.
    If all of the above treatments fail. Id say your latte glasses are beyond help. New set of Duralex glasses dont cost much more than ten bucks anyway.
    Warren
    14,665
    we soak our in bleach in the cafes, or a little elbow grease with detergent and a fine scourer will do it too. Am yet to see a glass which had to be chucked out... (except the broken ones, of course ;).)
    Nov 2004
    302
    Well nobody can say I didnt try. Every household and most commercial chemicals and even two religous ceremonies refused to budge the deposit. >:( Prolonged soaking and even longer cursings didnt help. ??? So out they went. In the end, my wife was so frustrated with the laundry sink being full she kindly bought me some more. She is a good woman. :)
  1. Replies: 7
    Last Post: 30th August 2010, 08:16 AM
  2. New latte glasses
    By greenman in forum Brewing Equipment (non-machine specific)
    Last Post: 14th December 2008, 09:18 AM
  3. Latte glasses
    By Bart in forum General Coffee Related...
    Last Post: 6th June 2007, 03:26 PM
