Results 1 to 4 of 4
Thread: Fatal Overdose
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,140
    Fatal Overdose
    I guess every machine is different - I wouldnt know as I have only used my Perfetta - but I find dose is everything and on the occasions that I slightly overdose I can guarantee problems with the pour.
    I slightly overdosed the double basket this morning and got serious channelling with only one of the spouts delivering anything. I think that when I overdose I tend to tamp a bit firmer to try to create the required amount of clearance at the top, instead of just unloading the basket and reducing the quantity slightly. The combination of slight overdose and firmer tamp is fatal. Anyone else notice this?
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Re: Fatal Overdose
    If I find that the dose is more than required for the correct level I generally unload the whole basket back into the doser and redose to the right dosage for the correct tamp level. Yes, I find overdosing and tamping harder to get to the right level will effect the shot. I think there is some allowance if its just a slightly harder tamp but if its a significant more pressure on tamping to get the right level it will generally cause some issues.
    Did you try my rice test method for tamp level? Curious how it compares to your current tamp level.
    http://www.youtube.com/watch?v=lJzmcM2AUS0
    May 2008
    Central Queensland
    1,140
    Re: Fatal Overdose
    Thanks for the helpful suggestion saoye. That is a clever method!
    I need to be more disciplined and just unload the basket when there is slightly too much grind. The difference between just right and too much is so small that the temptation is to just squeeze it in a bit more - which is fatal.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    Re: Fatal Overdose
    Quote Originally Posted by 59646860720B0 link=1328441258/2#2 date=1328516019
    Thanks for the helpful suggestion saoye.* That is a clever method!
    I need to be more disciplined and just unload the basket when there is slightly too much grind.* The difference between just right and too much is so small that the temptation is to just squeeze it in a bit more - which is fatal.
    As an alternative to emptying the basket back into the dosing chamber and starting again I sometimes sweep the excess grind out of the basket with a slight scooping motion with my finger (as opposed to a level sweep) so as to compensate for the excess grind - works particularly well when youre busy making a lot of coffees - or if the coffee is being temperamental and your minor adjustments to the grind settings are yet to have the desired effect...
  1. overdose?
    By BigRed in forum General Coffee Related...
    Last Post: 16th December 2009, 09:47 AM
  2. Overdose
    By TEPIN in forum General Coffee Related...
    Last Post: 15th August 2007, 09:56 PM
  3. caffeine overdose
    By Javaphile in forum General Coffee Related...
  4. overdose/underdose and how it affects taste
    By dsc in forum General Coffee Related...
    Last Post: 3rd April 2007, 04:56 AM
