Results 1 to 8 of 8
Thread: New member, first post
    superg
    ive been lurking around here for a while and thought id finally join.
    Ive got a Gaggia Coffee Deluxe and a Sunbeam Grinder, here is a photo of a shot i pulled over the weekend does it look good?
    Its just using lavazza beans, ive just been trying a few different brands to see the differences, what beans would you all recommend i try next?
    KJM
    KJM is offline
    May 2007
    688
    Re: New member, first post
    Welcome to Coffeesnobs!
    Quote Originally Posted by 414742574055320 link=1328492088/0#0 date=1328492088
    Looks like it is lacking the "reverse Guiness effect" but pretty respectable for the Lavazza beans..
    If you want to try something very decent, and appropriately fresh look over there <--- and click on "Roasted Coffee" and goto "Espresso Wow" ;D
    Of course, there is bound to be a local roastery somewhat closer than Andy to you, but you really cant go wrong with Wow. It has that name for a reason!
    I think youll find there is a taste explosion with the fresher beans.
    My $0.02!
    /Kevin
    Dec 2008
    1,039
    welcome :)
    Quote Originally Posted by 292F2A3F283D5A0 link=1328492088/0#0 date=1328492088
    anything "fresh" - roasted within 1 - 3 weeks ago. If theres no "roasted on" date on the packet, dont buy it!
    How does the crema settle after a few seconds? And most importantly, how does it taste?!
    superg
    Didnt really take much notice on how it settled, how should it be settling?
    Also what do you mean by its lacking the reverse guiness effect?
    Dec 2008
    1,039
    Quote Originally Posted by 767075607762050 link=1328492088/3#3 date=1328564697
    It shouldnt (not by much anyway). Its not uncommone to have a frothy looking pour which settles to little/no crema after a few seconds. If you end up with (for example) half crema 10s after stopping the extraction then its just one indicator of a good shot. The numbers are made up to illustrate the point.
    But most importantly:
    Quote Originally Posted by 6C646C6B6167050 link=1328492088/2#2 date=1328517536
    If it tastes awesome it is awesome ;)
    KJM
    KJM is offline
    May 2007
    688
    Quote Originally Posted by 6F696C796E7B1C0 link=1328492088/3#3 date=1328564697
    You probably need to see some Guinness poured ;D But seriously - this is nothing more than the very fine bubbles and oil (apparently) flowing downwards in the glass in a kind of wave like way. You tend to get that with fresh beans and perfect shots. The effect is transitory and after a while you end up in the state your shot above looks like. But that is usually after the shot finishes!
    As Ian said above: How does it taste?? The accepted wisdom is that you should be getting your 30ml in 20/25/30 seconds (delete as appropriate, depending on which wisdom source youre using :o). If thats how you got the shot above, then youre in the ballpark - and you can play. Try pulling it short - youll probably get a slightly sweeter taste, for example.
    Getting some known-fresh beans and trying those would be a good thing to do though - so you can see what (if anything) is missing/wrong/different (again, delete as appropriate) from what youre doing now.
    /Kevin
    Dec 2008
    1,039
    oh by the way, does the Gaggia use pressurised baskets or pressurised pf? (can you see light through lots of holes in the basket? can you see light through the pf spouts?)
    If not, then the crema is "fake" as its created by squeezing coffee through a tiny pinhole to froth it up and create some back pressure in the puck.
    yours may or may not be like this, Ive seen someone mention Gaggias have these baskets but Im not sure.
    superg
    Deifinately unpressurised, im doing the spv mod tonight and then when i get my next pay im going to buy the classic OPV so i can measure pressure and adjust to the correct 9 bar aa i was reading they come set at a higher pressure from factory
  1. Am I a member?
    By cuppacoffee in forum Off Topic
    Last Post: 9th July 2011, 02:17 PM
  2. new member needs help
    By Markyj in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th April 2008, 08:20 AM
  3. new member
    By Javaphile in forum General Coffee Related...
    Last Post: 12th June 2007, 11:48 AM
  4. Re: New member here
    By Dimal in forum General Coffee Related...
    Last Post: 28th May 2007, 12:48 PM
  5. New Member :)
    By SupremeRoasters in forum Brewing Equipment (non-machine specific)
    Last Post: 14th July 2006, 01:35 PM
