Results 1 to 4 of 4
Thread: Perfect Crema With One Roaster But Not With The Other
    dman777
    I have used Redbird Espresso and have gotten great crema...tiger stripped with the molted look.
    But my favorite beans are from Paradise roasters and with their coffees I can not get the same crema. If Im lucky I can get the Cinnamon sprinkled look. Is it my technique or are these beans from Paradise roaster not capable of the tiger stripped crema with the molted look?
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Re: Perfect Crema With One Roaster But Not With The Other
    Hi dman777,
    Majority of coffeesnobs are Australian and comparing shots from from American roasters and asking for opinion on these specific roasters is probably not going to get too many responses. The only thing I could possibly contribute is to ask if you adjust your grind settings from one roasters beans to another? It may require some slight adjustments. You mentioned your favourite beans are Paradise Roasters despite not getting the same crema. Its the taste that counts in the end.
    dman777
    Yes, I usually adjust my grinder to adjust taste the most....rather than temp.
    I like long pulls with the initial stream black stage lasting longer than normal, so there is more flavor. A 14 gram shot will usually last about 35 seconds and produce 1 1/2 ounce shot. I try to stay in this range because it gives me the flavor I like most.
    Not sure why this way will pull perfect crema with one bean/roaster but not another.
    Dec 2008
    1,039
    A 14-18 g double should give you about 2 ounces. However, at about 9 bar this should happen in about 25s not 35, so with my limited experience I would suggest youre extracting at lower pressure.
    It may well be that blend A produces more crema at this pressure than B, or perhaps youre grinding a bit course to compensate for the lower pressure and this is working better for A over B.
    In either case you may (or may not) find better results* for both blends by slowing it down a bit. Perhaps it doesnt taste good like this for other factors you havent experimented with yet?
    But in the end as we say "its the taste that counts", but good crema is impressive!
    HTH
  1. Gaggia Perfect-Crema device is the BEST!
    By dane5431 in forum General Coffee Related...
    Last Post: 12th November 2010, 11:17 PM
  2. Crema Sucks. Try removing the crema and doing a double blind test.
    By ezralimm in forum General Coffee Related...
    Last Post: 8th April 2010, 01:03 PM
  3. A (Epic?) journey in search of my perfect roaster
    By Javaphile in forum Roasters
    Last Post: 8th August 2007, 02:16 PM
