Results 1 to 12 of 12
Thread: Grindz grinder cleaner...issue?
    Nov 2010
    88
    Decided to clean all my coffee gear today and started with the grinder which all came to an abrupt halt. Opened a small packet of Grindz tipped the pellets into the hopper switched on machine within a couple of seconds the grinder seized up.
    Anyone else had a similar experience? :-? :(
    Aug 2004
    2,312
    Re: Grindz grinder cleaner...issue?
    wind the adjustment out to a way more coarse setting.
    Nov 2010
    88
    Thanks Attilio.
    Ipullled out the hopper emptied out the pellets to see if I could see what the problem could be, naturally didnt see anything untoward.
    Got a socket onto the locknut ( thanks for the tip Andy) to turn anticlockwise to see if I could loosen the blockage, the burr moved freely, turned clockwise same result. Plugged the grinder in, switched on and all good 8-)
    In future will definately set the grind to a much coarser setting.
    Am curious if anyone else has had this issue with grindz? (Not dissing the product just interested)
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    948
    I have used Grindz several times and have not had this problem. I do not adjust the settings at all. I may do that now as it has been identified by your problem.
    Oct 2011
    Gold Coast
    223
    Havent used them for some time but dont the instructions suggest a medium setting ?
    Dec 2007
    948
    dabbler you are quite correct. Now I know why I should read instructions :o
    Oct 2011
    Gold Coast
    223
    Quote Originally Posted by 3215000F610 link=1333683797/5#5 date=1333687518
    dabbler you are quite correct.* Now I know why I should read instructions* :o
    Oh, I never said I had read the instructions. (At least not beforehand). I really just did what my bro-in-law told me. I should add it was the only time he let me change grinder settings. Changing back was a task for more experienced souls.
    Nov 2010
    88
    Quote Originally Posted by 323734343A3324560 link=1333683797/4#4 date=1333687318
    No istructions with mine was a small packet that came with the grinder.
    Will have to remember in future to change setting ;)
    Oct 2011
    Gold Coast
    223
    Quote Originally Posted by 4E404776616965040 link=1333683797/7#7 date=1333689615
    Will have to remember in future to change setting* ;)
    That does make it a little harder doesnt it ?
    At least the solution from the forum came quickly.
    At least youve got me thinking I should pick some up soon.
    Nov 2010
    88
    Indeed, very helpful..... thanks all.
    Well all my coffee gear all cleaned and the coffee tastes amazing, I think it might be a bit like after you wash your car and it goes faster ;)
    Mar 2004
    Internet
    17,515
    Glad nothing was broken.
    8-)
    ...another reason to buy good gear, a lesser grinder might had done a fair bit of damage to the shaft or carrier when the burrs stopped.
    Nov 2010
    88
    Thanks Andy.............Loving the Macap. 8-)
  1. Grindz for Smart Grinder?
    By Rusty in forum Grinders
    Last Post: 29th August 2011, 10:16 AM
  2. Grindz Grinder Cleaner
    By Squirrelgrip in forum Grinders
    Last Post: 2nd July 2009, 03:22 PM
  3. Grinder cleaner - rice
    By flynnaus in forum Grinders
    Last Post: 5th July 2008, 01:53 PM
  4. Re: Grinder Cleaner.
    By hazbean in forum Grinders
    Last Post: 26th November 2007, 08:07 AM
