Results 1 to 5 of 5
Thread: Descaling aluminium thermoblock
    May 2006
    13
    What is the most commonly used descaling agent suitable for espresso machine with aluminium thermoblock?
    Thanks.
    16,668
    Re: Descaling aluminium thermo-block
    Welcome to CoffeeSnobs Starbugs [smiley=thumbsup.gif],
    Hmmm, harking back to my bad ol Sunbeam days :P, I used to use the stuff they sold in supermarkets and Kmart/BigW, etc to descale their brand of steamndry irons. Used to work pretty well. Most of us with dual purpose, single "copper or brass" boiler machines like the Silvia for example, generally use Citric Acid diluted with water. If you do a search through the forum with citric acid as your key-words, Im sure youll turn up some useful threads,
    Aug 2006
    55
    Re: Descaling aluminium thermoblock
    http://www.cafetto.com/homeprod.htm
    Espresso Clean @home
    Espresso Clean @home is designed to clean, descale and sanitise the brewing group, handles, filters, the milk line system and boilers of domestic and small office machines. It has a unique application where the machine has no programmed cleaning cycle (as distinct from descaling or decalcification cycle) and the brewing group cannot be removed for cleaning.
    Available in
    250ml bottle
    May 2006
    13
    Thanks Mal & Tanghy for your inputs.
    I was told the type of aluminium thermoblock that I have is coated with a protective layer. Therefore, acid based descaling agent can be safely used without etching away the aluminium.
    Cheers.
    16,668
    Good one Starbugs [smiley=thumbsup.gif],
  1. Roasting in Aluminium? -
    By drewjane in forum Off Topic
    Last Post: 3rd August 2010, 01:50 PM
  2. Aluminium Stove top and growth
    By Springbok in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 20th June 2010, 04:19 PM
  3. Polished Aluminium K3 Touch ???
    By kbc in forum Grinders
    Last Post: 4th April 2010, 03:47 PM
  4. Descaling solution still in water after descaling em6910
    By CaffieneHit in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th May 2009, 07:00 PM
