Results 1 to 11 of 11
Thread: Tray for grinder... any suggestions?
    May 2007
    725
    I suppose this affects doserless as well as doser grinders as well. Ive got a Gaggia MDF which has a doser (albeit a poor excuse for a doser), whether I dose straight into a PF or into a container to take to the office, there will be grounds everywhere on the benchtop. Thats because some will stick onto the chute bit, some at the bottom of the doser when the PF overfills and the mountain of grounds touches the topside of the doser (the MDF doser is too close to the PF fork...). Whatever the reason, there will be ground coffee everywhere. i was thinking of getting a tray where I can sit the grinder on so all the loose grounds will be confined to the tray and not the bench. The tray Im thinking of should have slightly raised sides (like the KFC or food court eat-in trays) but looks better. Any ideas?
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    851
    Re: Tray for grinder... any suggestions?
    Gday NTE,
    a method I used to tidy up my grinder area was to use a piece of clear stiff plastic from a shirt box. I cut out some slots so it would slide out from underneath the grinder for cleaning. It wasnt exactly good looking, but it worked and it wasnt very noticeable on the counter top.
    17,475
    Gday NTE,
    Ive also seen some pretty useful looking flexible cutting boards for sale in Woolies and BigW in a wide range of colours, so that might be another alternative....
    May 2007
    725
    I have those flexible cutting boards but they were flat all round. I need something with raised sides.
    Sep 2006
    Sydney Straya
    144
    Try this
    Cost - nil
    Time to manufacture - minimal
    Effectiveness - excellent
    Copyright - none
    Go for it
    Sep 2006
    Sydney Straya
    144
    Its a cut down 2 litre plastic milk container
    17,475
    You must be a messy bloke NTE ;).... I was using something similar with my Rocky and it always managed to contain all the extraneous grinds. When cleaning up I just tipped Rocky back a little, pulled the plastic sheet doohickey out from under and emptied/wiped out into the sink and replaced 8-). Anyway, hope you find what youre looking for mate,
    May 2007
    74
    If you want a bit of Bling, you could try looking for Bar drip trays.
    http://barware.cart.net.au/details/789776.html
    17,475
    Quote Originally Posted by mylesau link=1186637938/0#7 date=1186652715
    Good thinking agent 99 [smiley=thumbsup.gif]
    May 2007
    725
    Quote Originally Posted by wingnut link=1186637938/0#5 date=1186651227
    This is brilliant! If I had a doserless, I would have done that!
    May 2007
    725
    this is exactly what Im after! Ill have to pass this through to the BOSS before getting final approval...
  1. New grinder suggestions please
    By fullbora in forum Grinders
    Last Post: 17th November 2009, 06:54 AM
  2. Grinder Suggestions?
    By SoupRQT in forum Grinders
    Last Post: 8th November 2007, 09:00 AM
  3. Suggestions for best espresso grinder for home use
    By Thundergod in forum Grinders
    Last Post: 20th April 2007, 10:51 AM
