Results 1 to 12 of 12
Thread: Max Taste. Min Caffeine. Any ideas?
    Apr 2008
    370
    Hi, i was wondering if its possible to make a shot as tasty as possible without making it too bitter.
    Any ideas?
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    943
    Re: Max Taste. Min Caffeine. Any ideas?
    Depends a lot on the bean but stop the shot before you get any blonding. ;)
    10,496
    Snap Stan.
    Ditto.
    Feb 2006
    2,334
    Decaf? Ive tasted some awesome decaf...when done right it can be beautiful
    Jul 2007
    Werribee, Victoria, Australia
    737
    Hi Ezraimm,if its less caffiene youre after try a shade grown coffee, I hear [mostly from coffeesnobs] that they are lower in caffiene. Or do what david says use decaf
    Nov 2006
    1,077
    Hi there
    The decaf mocha Java from the beanbay is an awesome bean. :)
    I have substituted it at work when they ran out of beans and no one was the wiser about the caffeine side of things, they just thought i had got a different coffee because we had run out.
    Mal
    Jul 2007
    2,286
    I like my doppio ristretto.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    try making a piccolo using only the first 20mls of a single pour, then top with about 60ml of milk in a shot glass or a small tea glass (or similar)
    or better still pour a ristretto in a demitasse and top with milk
    remember the longer the pour the greater the caffeine (and bitterness) which is why I can drink (but dont recommend) 9 short poured espresso coffees in a day and still sleep at night!
    Pat
    psaigh
    Check out the relatively new strain of Opus 1
    http://blog.brotherhoodofthebean.com...rst-naturally/
    Sep 2006
    580
    As Mal (bolb) said, the mocha java swiss water decaf is a nice drop if youre looking for decaf, but I dont think thats what ezralimm was asking, I think a well dosed and tamped single shot of decent fresh coffee restricted to a ristretto (20 ml shot) is what hes looking for.
    Ray.
    Apr 2008
    370
    Thanks for the suggestions guys.
    Yup, the 20ml shot was what i was looking for.
    Im using a cheap machine with a pressurized basket so, after a few complete disasters (stuck/blocked basket), i found out that my best bet would be to stick with a double basket, put about 60% more grounds than i would in a single basket, and tamp a little harder (exactly 25kg... yup, i actually got a weighing scale to tamp on). I then dump the first 1.5 secs of flow and take the remaining 16-18 secs of flow. It is roughly two thirds of a shot glass (not including crema) and has an acceptable taste.
    Oct 2006
    817
    Ive heard that its possible to pull out the plastic inserts on some pressurized baskets, which vastly improves the shot
    Also, what coffee are you using and has it been freshly roasted?
    Pat
  1. New Machine - Any Ideas
    By youngbarista in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 9th August 2011, 10:29 PM
  2. Need some other ideas for problem
    By NeedCoffeeeee..... in forum Brewing Equipment (non-machine specific)
    Last Post: 9th January 2008, 12:42 PM
  3. New roasting ideas
    By Javaphile in forum Roasters
    Last Post: 28th January 2005, 06:43 PM
