Results 1 to 25 of 25
Thread: Naked Portafilter
    Jul 2008
    Blue Mountains
    136
    Naked Portafilter
    hello, can anyone tell me the advantages/disadvantages of a naked portafiller, cant find a thread on it, and was just watching some vids on youtube and a lot of people where using them.
    thx
    mod edit- corrected topic spelling
    14,665
    Re: Naked Portafilter
    Quote Originally Posted by fishinglizard1972 link=1220348873/0#0 date=1220348873
    thx
    Hi fishinglizard...
    I used the search button up yonder ^^^^^^^ on the term naked portafilter and found a heap of hits in multiple threads...
    Give it a shot ;)
    2mcm
    Jun 2005
    86
    Ive just ordered one to (hopefully) help me learn how to dose and grind better. *Its more of a learning tool from what I gather, although it should also be a good conversation piece when pulling a coffee for friends at home.
    Mar 2008
    554
    Quote Originally Posted by bogongtiger link=1220348873/0#2 date=1220449943
    Ive just ordered one to (hopefully) help me learn how to dose and grind better.....
    You should already have a handle on the grind. The bottomless will help with dose, distribution, and to a lesser extent, possibly tamping. it makes it a simple matter to see if the distribution was uneven as the coffee will flow later some areas than others- sometimes seconds later. It will reveal fractures n the puck as watery, thin, and fast flow. *Sprites will also indicate problems- these micro streams which shoot out at all sorts of weird angles can be exciting, and if you like to watch closely, be sure to wear glasses. And as you indicated, watching the flow start to dribble out the holes in the bottom of the basket, then with great viscosity, join together into one delicious stream makes for great entertainment.
    sdg
    sdg is offline
    Mar 2008
    368
    Quote Originally Posted by Randy G. link=1220348873/0#3 date=1220453952
    You should already have a handle on the grind. The bottomless will help with dose, distribution, and to a lesser extent, possibly tamping. it makes it a simple matter to see if the distribution was uneven as the coffee will flow later some areas than others- sometimes seconds later. It will reveal fractures n the puck as watery, thin, and fast flow. Sprites will also indicate problems- these micro streams which shoot out at all sorts of weird angles can be exciting, and if you like to watch closely, be sure to wear glasses. And as you indicated, watching the flow start to dribble out the holes in the bottom of the basket, then with great viscosity, join together into one delicious stream makes for great entertainment.
    Sprites, huh. Is that what those are called? I thought they were called "quick, get an umbrella" :o
    Ive had a bit of run of these recently, since I stopped "updosing". Just cant seem find a way to get good distribution and have room between the shower screen and the puck. :(
    Any pointers would be gratefully received :D
    Mar 2008
    554
    Without quoting paragraph after paragraph, the easiest thing is to read my treatise:
    "HOME BARISTAS GUIDE TO MAKING QUALITY ESPRESSO"
    Go to my website (www.EspressoMyEspresso.com)
    Look on the right side in the "HOW-TO PAGES" section
    Its #12.
    sdg
    sdg is offline
    Mar 2008
    368
    Hi Randy,
    thanks for the link. "Treatise" is right ;D -- still reading...
    While on the topic of your "ongoing internet novelette" -- this is a most excellent resource, esp. for Silvia owners but generally too.
    So Ill take this opportunity to say a heartfelt thanks for actually typing all that stuff up :o (and posting it) 8-)
    May 2007
    302
    I started reading at lunchtime yesterday also and man there is a lot of info there!!
    I have already started to check things with my dosing etc. It will definately be bookmarked for reference.
    When I can afford a naked I think it will be a great purchase to help me in my quest to get out of the little leagues
    May 2008
    437
    You can see exactly whats happening from start to finish in the pour. You can analyse to your hearts content or just get lost in the beauty of that smooth tiger-striped flow.
    You can fix definite technique problems with distribution and tamping. And decide if you really want to drink that shot you just saw, or give it a miss. And you can start and stop the shot precisely when you want to - even *::) *up or downstream of the filter basket. *;D
    Distribution problems: variations in the start of the flow around the basket.
    Tamping problems: angled tamping will show in early blonding on one general region of the basket.
    Dec 2010
    67
    Naked vs conventional portafilter
    Aa a relative newbie to espresso machines (since January) Im wondering why the conventional dual-spout portafilter is the standard item on machines? I used the stock-supplied portafilter on my Silvia until last week when I put the nude one on; it hasnt been off since. I presume the dual spout is to allow two cups to be made, but I really wonder how many shots are poured for two? The naked kit shows the shot flow so much better, is easier to clean, and easier to handle in a sense (its lighter for one thing). I still have the dual-spout handy with the blind portafilter always locked in so I can do a loose or full back flush without changing baskets, which is pretty convenient. Reading some threads here suggests that the naked portafilter is some kind of equipment exotica, but it really makes much more sense than the dual-spout. Am I missing something here?
    Jun 2005
    Newcastle
    230
    Re: Naked vs conventional portafilter
    If you search back, there were some discussions from people who could taste the difference and changed back from the naked.
    I found the naked messier - no matter how careful my attention to dose/distribution/tamp and how good the pour looked, I still had instantaneous micro-jets heading off in all directions.* They were hard to see unless you had bright light on it - possibly just coffee particles shifting around the exit holes at the start of the pour?* The naked is good every now and then, to make sure you havent wandered off in the wrong direction, but for everyday I prefer the single spout.
    Some just take the double spout off so the pour drops straight down or you can get a single easily enough - http://www.coffeeparts.com/rancilio/700024.htm
    10,496
    richard Ive been doing the same since buying my naked group handle.
    The dual spouts are handy when people are over and it only takes a few seconds to swap the blind filter for a double basket.
    Id say the twin spouts are standard because they can cater for both two cups or one.
    Mine fit easily over a single shot glass if I want a double shot and some people let the second shot run into the drip tray if they want a single and only use the double basket.
    Others collect the second shot and keep it for iced coffees etc.
    So its not a matter of how many shots are poured for two because the two spouts easily cater for one and it saves having to have a second, single spouted handle or changing the spout.
    Remember coffee machines started out as commercial equipment and convention is based on their evolution from that starting point; double spouts make sense.
    Nakeds are a modern variant and I bought mine to examine my technique.
    I think now, most of the time, I dont need it any more on most days for that purpose.
    However, now I use it every day because it looks cool.* 8-)
    Jul 2007
    2,288
    Ive tried singles, doubles, none, and bottomless--and the bottomless is the one that stays on my machine.
    Scarey--I too had spritzes for a while. They went away and the shots improved when I used the Weiss Distribution Technique. This too is now my standard.
    Jan 2009
    168
    Personally, I enjoyed the aesthetic of the naked, and still have some handy for those showful moments. But I had an issue with the aeration of the shots falling a further distance, and of course the poor judgement by eye-sight alone on the weight/volume of said shots.
    Senior Member benandfaith's Avatar
    Jun 2007
    Indooroopilly
    253
    Ever since I got my naked PF, which was pretty much when I bought my first machine (Silvia), I used to use the naked almost exclusively when making coffees as I usually drink double or double ristretto based caps/lattes. Recently, Ive been drinking piccolos about 50% of the time, so the double spout has come back into use!
    I love the look of the naked pour!
    Plus I get to check that my distribution and tamp is good/even.
    Incidentally, I used to do the tamp - tap tap - tamp - polish technique and found that quite often Id get spritzes (gotta love that word!), no matter how consistent I thought I was doing my dose/distribution/tamp. With the Silvias more industrial look, it didnt bother me as much, but with the beautiful Zaffiro, it bugged me big time!
    I then switched to tamp once and polish and I have not had one spritz yet! Anyway, Im pretty sold on the tamp once and leave it alone method now...
    My below average taste buds cant tell the taste difference others speak of.
    Jun 2010
    107
    I found that when I knocked the puck out with my single and double spout, bits of liquid stored within the spouts went everywhere. Its not much, but enough to have to clean afterwards. With the naked p/f I dont get that. Tastewise, meh, neither here nor there. Visually, I rather enjoy the spouted p/fs. I love watching the crema fall out of the spout.
    But i hate cleaning. So the naked one wins.
    Aug 2010
    360
    Quote Originally Posted by 417D607B717067727A71150 link=1300572307/2#2 date=1300579082
    Ive actually watched a barista make a double shot for a customer by using a double handle, putting the cup under one spout and letting the other run into the drip tray, then repeating the process for the second shot. When I asked them why they didnt just centre the cup and collect both streams from the handle (cup was big enough) they looked at me like I had just grown an extra head!
    And then when I ran a few test shots after servicing their machine they had the cheek to tell me off for wasting coffee! ::)
    A_M
    A_M is offline
    Mar 2006
    6,381
    I am not going to comment on the list to the right (select the button that Lists all Videos) as to the naming or accuracy of the 23 listed.
    But it will give you an idea and has a few different ones all in one place; thus a handy link to have.
    However it may be me, but many are not great and in fact, look very ordinary; one is called "BADxxxxxx" ..... But I would suggest maybe better than others that are called "Perfect xxxxx"* ;D ;D ;D ;D
    Thus a warning.* Not all one sees and reads on the web is true and correct.*
    And that even goes for some stuff posted here on CS* ;)
    Nakid pours in a* list
    Apr 2011
    152
    Could someone please explain the use of the bottomless porta filter?
    14,665
    Quote Originally Posted by 756E6F786C30010 link=1220348873/18#18 date=1303075300
    Hello Tony,
    I used quick search up yonder ^^^>>>> on the term naked portafilter and found a heap of hits in multiple threads- including this one where I have*relocated your post. Its always worth trying a search before reinventing the wheel...* :-?
    Apr 2011
    152
    Hi 2mcm,
    I put a search in for bottomless porta filter and got no matches, the reason I asked the question is because i dont know the difference ,if there is one, between a naked or a bottomless porta filter. Thank you .
    Nov 2010
    448
    Quote Originally Posted by 756E6F786C30010 link=1220348873/20#20 date=1303116505
    bottomless = naked.
  23. #23
    150
    You will have more luck if you make sure portafilter is one word. Good luck.
  24. #24
    Jan 2011
    249
    You have potential to get better shots from a naked portafilter because you can see what is going on both in terms of any channeling and also in terms of when the pour is blonding.
  25. #25
    Apr 2011
    152
    Thank you, I will check that out a bit closer when I get my new machine with the 58mm pf
  1. Naked portafilter
    By afton in forum Brewing Equipment (non-machine specific)
    Last Post: 16th July 2008, 10:32 PM
  2. Naked Portafilter
    By proftournesol in forum General Coffee Related...
    Last Post: 20th May 2008, 12:25 PM
