Results 1 to 24 of 24
Thread: Lavazza Blue
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,085
    Lavazza Blue
    Well the self-serve coffee machine is installed at work. It is called the Lavazza Blue system and is a capsule-based system like the Nespresso-based coffee makers. There are about 8 different capsule blends which come with their own descriptions and strength ranking.
    The first 30 capsules were consumed on the first day (everyone in the office tried one) and we now have a couple of hunderd more which sell for $1. each.
    The machine is electronic and dispenses a short black or a long black of about 2/3 of an Americano cup, but also allows the operator to vary the amount of water in the pour. Comes out with a good looking but pale crema.
    Definitely has some sort of coffee flavour although I havent quite figured out what. They describe some of the capsules as having a creamy flavour (which is not a description I would have applied to espresso) but I agree they taste a tiny bit creamy (not a characteristic I like).
    Machine has a little steam wand that does quite a good job for the milk freaks.
    I have only had one coffee to try it but would have to say it tastes different from one of my colleagues Nespresso machine. Dont think I will be retiring my plunger any time soon. Anyone else have any experience of these things?
    Jul 2007
    2,286
    Re: Lavazza Blue
    No, but you can bet with some certainty that the ground coffee in the capsule is older than 3 minutes!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Lavazza Blue
    Look at the volume of coffee to start with...
    For a $ you can even afford to pull one apart...
    Quick and dirty from the ones I have seen and the usual crema enhancement to give that coffee look.
    A mate quite likes the one in his office area, as he says its better than instant.. The one at work has some issues with steam and the staff have requested people not to use it, as the noise annoys them... Oh we are so politically correct some times it is beyond a joke.
    10,496
    Re: Lavazza Blue
    Their drinking instant annoys me.
    Apr 2007
    1,687
    Re: Lavazza Blue
    If its anything like the nespresso capsule I cupped the other day at my parents joint, I bet it sucks big time. I could harldly stomach it. I had two sips for confirmation. Its a sin.
    Mar 2004
    Internet
    16,685
    Blog Entries
    1
    Re: Lavazza Blue
    I can see a place for pods and pads in office environments because they are clean(ish) but most places will install a super auto instead.
    At least in a superauto machine you can use good, fresh beans.
    Most pod machines that I have seen will pull a whole cup of water through that little teaspoon of instant and grounds... **shudder**
    May 2008
    Central Queensland
    1,085
    Re: Lavazza Blue
    Interesting comments. I wondered about the issue of crema enhancement - that might account for the slightly foreign taste. The Instant-drinkers think its great but I would rate it one step above Instant and nowhere as good as a plunger.
    I was not impressed with my colleagues Nespresso as the shots (regardless of type) all tasted very acid to me.
    Nov 2008
    361
    Re: Lavazza Blue
    Drip filters are the best option for offices IMHO. makes a good 10 cups in a few minutes, and is easy to make an OK coffee that beats instant by a long way. Much cheaper too.
    Apr 2007
    1,687
    Re: Lavazza Blue
    ....and more caff to dose up the workers, than the spro!
    Site Sponsor
    Jun 2006
    257
    Re: Lavazza Blue
    Iv never tried the pod system but just like anything you always want to try it once and more then likely never again.
    Actually saw a commercial machine for cafe that used a pod setup somewhere on the net.
    Jan 2009
    7
    Re: Lavazza Blue
    We have a DeLonghi nespresso pod thing in our office and its not that bad when you find the right pod, alot of them have custom pods you can buy that differ from the ones that come with it and some are actually drinkable.. sure nothing great but they are sometimes the best of a bad situation.. ::)
    10,496
    Re: Lavazza Blue
    Quote Originally Posted by 5E6E757B7468796E4F7578791C0 link=1232016427/9#9 date=1232431159
    Theres a bakery in North Sydney that uses Illy pods in their machine.
    Nov 2008
    62
    Re: Lavazza Blue
    The problem with Illy pods is the coffee is invariably stale and oxidized not long after you open to box. You at least get the right amount. Every cup Ive had from this system has been thin and bitter, but they are clean to use.
    The Nesspesso system presumably flushes the canister with nitrogen after initial filling to get rid of the oxygen, so while it may be stale, has not been oxidized, so, if you get the right blend, tastes fine.
    We had ground coffee and espresso machine at work and with very low volume found it was almost allways stale and a pain to clean up after. Nespresso fixed that (at a price)
    Jan 2006
    40
    Re: Lavazza Blue
    I introduced an espresso machine at an office I worked at a little while back.
    Coffee time was a big hit.
    I took the machine with me when I finished my contract with them.
    They subsequently got a $1/pod machine replacement.
    Coffee time was never the same. *Soon most folk every went their own way, buying coffee out, etc., even though the employer was footing the bill for the pods.
    Quote Originally Posted by 5C616D65770E0 link=1232016427/0#0 date=1232016427
    first 30 capsules were consumed on the first day (everyone in the office tried one) ... which sell for $1
    Thats $7500/year for 1 coffee/person/day for 30 people.
    That would buy a plumbed in espresso machine, grinder, good fresh roasted delivered coffee.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    Re: Lavazza Blue
    Theres two lavazza blue machines in almost every metro station in milano, they seem to get a work out even though in most cases there was also a bar 50m away (machine was cheaper :)), while a lifeless imitation of espresso I enjoyed the macchiatos and would be thankful to have one at work.
    May 2008
    Central Queensland
    1,085
    Re: Lavazza Blue
    The Lavazza Blue machine continues to go strong. I was initially a bit puzzled at its popularity as I didnt rate the brew very highly, but on reflection I have realised that only a few staff have their own espresso machines at home and the rest are accustomed to just using Instant, supplemented by the occasional cafe cup. These folks are just not as fussy as the fanatics and see it as a step up from Instant. Interesting.
    Dec 2008
    1
    Re: Lavazza Blue
    We just got a lavazza blue pod machine at work (not my choice). The three espresso blends I have tried so far all taste odd to me - possible the "crema enhancement" mentioned above. I am quite sensitive to tasting things like that.
    Does anyone know if alternative blends are available in compatible pods? Or where you can buy the blends (not in 100 pod packs)?
    I also tried searching for this thread (pod, pods, capsule etc - not of them made it come up) and it didnt appear.
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Re: Lavazza Blue
    Quote Originally Posted by 797E707F63647F76737860170 link=1232016427/16#16 date=1271315395
    Theres a guy called "Jimmy" who does "pods". If you google both those things together youll find his website.
    I dont know what it like and its probably rubbish, which you already know. It does give you an alternative though.
    Welcome to CS!
    May 2008
    Central Queensland
    1,085
    Re: Lavazza Blue
    A year or so down the track the usage on the machine has settled at about 90 pods a month which results in a slow build up in pods given the contract requirement to use 100/mth. Most coffee drinkers here are accustomed to their Instant and not discriminating at all. I have a little coffee-club going with my mates using a plunger or dripolator (depending on numbers) and prefer that to the pods. An espresso machine of any kind would not work here as some fool would stuff it up and I would be continually cleaning it as the yobbos would leave it in a discusting state. (they cant clean the sandwich maker or microwave so certainly wouldnt clean an espresso machine) I guess we can check it off as a failed experiment.
    Oct 2006
    504
    Re: Lavazza Blue
    We trialled one of these at work a couple of weeks ago, coffee was actually better than the superauto... the fact that the office lady who purchases the beans gets them at a supermarket certainly doesnt help
    ive been tempted to suggest st ali or ordering CS beans but think they would baulk at the cost, im known as the snob of the office with roaster, grinder and stuff at home but know not to knock the office coffee, heaven forbid it messes it up for everyone else
    might bide my time until people complain about it again then talk about CS - Andy will be back by then and we can order some beans
    Jul 2007
    2,286
    Re: Lavazza Blue
    Quote Originally Posted by 2D352F322E29243F32345D0 link=1232016427/19#19 date=1271331508
    Boy, youve got a lot more patience that I do. I throw disdain on the cr*p from the office stupid-auto and stale beans at every opportunity. 8-)
    Interestingly there are only two other regulars (and a couple of sort-ofs) who prefer my fresh home-roast through the Kyocera/Aeropress enough to make it, rather than just push a button.
    Jan 2009
    366
    Re: Lavazza Blue
    Ive mentioned before that at work they have a old Italian 2 group machine (hole cut in the bench, water drains straight through into a funnel into drainage) and a big old Bezzera grinder. Have also become known as the Snob of the place, and have a few people who I have offered my own beans to to try a cup here and regularly make one for them. Hey, weve got it, we should share it 8-).
    One of the ladies, who previously bought supermarket beans for a little machine at home has now asked me if Ill sell her a kilo of my roasted beans each month. Another has now said shell stop at a specialty coffee purveyor which Ive given a wrap (mentioned in the best coffees in Qld thread) on her way home rather than go to Glorias or Maccas. That there are those who still insist on their Internation Roast only confirms what many others have said...some people just dont want to know, or are too bloody minded. Their loss, not ours!!
    Im grateful we have such a machine here, it means all I have to worry about is remembering to bring beans in.
  23. #23
    Apr 2008
    370
    Re: Lavazza Blue
    Quote Originally Posted by 7E515B463F0 link=1232016427/5#5 date=1232114309
    The whole idea of nespresso is to not use instant coffee or grounds. Instead, readily extracted coffee is hermatically sealed in a foil lined capsule.
  24. #24
    Jan 2008
    1,756
    Re: Lavazza Blue
    Quote Originally Posted by 3A252D3E333632325F0 link=1232016427/22#22 date=1271369414
    But.....thats what it is........instant combined with stale grounds......sealed stale in their little cute foil wrapper! Yuk!
  1. Lavazza qualita rossa in Aus
    By Jimmytheboot in forum General Coffee Related...
    Last Post: 10th December 2010, 06:58 PM
  2. Lavazza a moda mio
    By calypsoAL in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 1st September 2009, 02:14 PM
  3. Re: Cheap Illy & Lavazza
    By Coffee_Kid in forum General Coffee Related...
    Last Post: 29th January 2007, 02:07 AM
