Results 1 to 9 of 9
Thread: Zip Boil temperature
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,084
    At work when I use my plunger I fill it from the Zip Boil. Without thinking too much about it I just assumed it would dispense water at around high eighties or early nineties.
    The other day I decided to test it with the milk thermometer that came with the new office coffee machine - 70degrees!
    Is this hot enough for good plunger coffee?
    (I wouldnt rave about my plunger coffee)
    Dec 2007
    921
    Re: Zip Boil temperature
    Dont trust those things they need to be regularly calibrated and can be out by heaps.
    10,496
    Its probably set low as an OH&S thing.
    May 2008
    Central Queensland
    1,084
    So what do folks think? Can you make good coffee in a plunger with hot water at 70degrees?
    Nov 2008
    164
    Hi Rocky
    I havent tried it, but why dont you make some plunger coffee using the same coffee and method, but with hotter water, and let us know how it compares.
    Cheers - Carrie :)
    May 2008
    600
    70 does sound very low - Im sure hte zip boiler at my work isnt far off boiling. Maybe time to get work to service it!
    May 2008
    Central Queensland
    1,084
    Quote Originally Posted by 4E6C7F7F6468460D0 link=1232016851/4#4 date=1232094173
    Hi Rocky
    Cheers - Carrie :)
    Hi Carrie, Yes, of course you are right, that is the obvious thing to do. Before I bought my Diadema I made my plunger coffee at home by boiling the electric jug which you would think would be producing water in the low 90s (?) . To tell the truth, the plunger coffee isnt remotely in the same class as the Diadema which is why I was fishing for comments about the impact of temperature on a plunger. I have to say the Diadema (& the good sponsors beans) has spoilt me for any other type of coffee.
    Nov 2008
    164
    Its such a lovely way to be spoilt though isnt it. *:D *Most indulgences that feel this nice come with a big lump of guilt *:P *
    Good coffee is perfectly good. - Carrie [smiley=engel017.gif]
    Mar 2006
    703
    Hi Rocky,
    I think that 70deg is too low to make decent plunger coffee.
    Allowing for the possibility of the milk thermometer being out a bit and reading low, you might have 80deg water coming out of the Zip boiler....still too low.
    Suggest try to force a heat cycle by using a lot of water to preheat your plunger, then pour as soon after the heat cycle stops (if you can hear it that is), maybe see if you can get the Zip boil serviced and see if it can be adjusted hotter, or find an electric jug to heat your water.
    While I prefer espresso based drinks, I do like, and enjoy, well made plunger coffee, which is mostly my staple when at work.
    Bullitt
  1. Epoca Won't Boil Water
    By rackxp in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 19th May 2013, 11:24 PM
  2. VBM picolo temperature
    By betterathome in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd March 2011, 01:07 PM
  3. How to Boil Water
    By seedlings in forum Brewing Equipment (non-machine specific)
    Last Post: 7th June 2007, 04:57 PM
  4. Cafe culture on the boil - The Sunday Mail
    By Andy in forum General News
    Last Post: 29th May 2005, 02:30 PM
