Results 1 to 5 of 5
Thread: This is complicated isnt it!
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,085
    As I spend more time with my new machine I am realising how complicated the whole good coffee thing is. I have been following the debate about double basket Vs single basket. I usually make coffee for myself & the Son, using the double basket. This morming Mrs Rocky wanted a Cappa so I made hers & Sons & then followed with mine using the single basket. Big difference.
    It took a full minute for my pour and nothing came through for the first 30 seconds. When it did it ran satisfactorily. It was not quite as good a taste as my prevoius mornings pour from the double basket - a tiny bit bitter with slightly less crema. The slow start alarmed me somewhat.(I did not have the presence of mind to check the pressure gauge)
    Maybe a slightly coarser grind (couple of notches) needed for the single basket? I dont think it was too firmly tamped.
    Feb 2006
    2,334
    Re: This is complicated isnt it!
    you need a different grind setting for the baskets....though this is not necessarily true. I used to run a 3 group machine with a single spout handle and 2x double spout handles. I dialed in the grind for the double baskets....and for single, I would dose slightly down, without altering the grind. Got some beautiful pours!
    A_M
    A_M is offline
    Mar 2006
    6,381
    For ease of use I use nothing but a double...
    If I want a week one or a small coffee, I just pull the shot short...
    Not ideal in some cases, but better than changing grinds / tamps and another PF to clean..
    Opps, am I laze....
    Mar 2006
    703
    As the others said,
    you can either use double basket for everything,
    cut the pour short for a single,
    use slightly courser grind setting for the single basket (suggest only one notch on a Rocky),
    or dose down a bit for the single,...
    or try a slightly larger single basket, which might work well with the dosing down approach, then no need to change grinder settings.
    Bullitt
    May 2008
    Central Queensland
    1,085
    Thanks Guys,
    I was gobsmacked at the difference between the single & double. I was getting worried the thing was going to blow up when nothing had appeared after 30 secs.
    I have used a single before although only maybe once or twice & did not have this problem. I felt I maybe underdosed a fraction but the tamp was just my usual one. I will give it another try this week and up the dose a fraction and make it a notch or two coarser and see what eventuates. Its a big experiment isnt it?!!
  1. Hey....Machine Isnt To Blame After All!
    By Meaty0 in forum General Coffee Related...
    Last Post: 4th December 2007, 08:14 PM
  2. Espresso. How sweet it is -- or isnt
    By robusto in forum General Coffee Related...
    Last Post: 26th March 2007, 10:04 PM
  3. Thank God this isnt true...... It isnt is it?
    By Dimal in forum General News
    Last Post: 21st October 2005, 07:30 AM
