Results 1 to 8 of 8
Thread: To brush or not to brush?
    Jan 2009
    162
    It had been suggested to me during my recent coffee machine purchase that a couple of backflushes after a shot is quite surfice for daily cleaning. So taking this view for the first week or so of ownership I did just that, only to find that whilst the backflush was adequete for cleaning the shower screen, it wasnt cleaining any small deposits in between the group head and screen. So I have since purchased a group head brush and found quite a difference. I still do the backflush (x3) after each shot but the brush just seems to finish it off nicely.
    So I am wondering, what is everyone else using (as a daily clean) on their machine?
    Apr 2008
    Brisbane
    5,113
    Re: To brush or not to brush?
    I use a wet microfiber cloth
    A couple times a week I remove the seal and screen for a wash and rinse
    Also clean the under screen area as lots of coffee oil deposits gather there
    I back flush mostly at the end of the day
    May 2008
    4,026
    I will do a plain water backflush and also jiggle . This means inserting the group handle (with blind filter) in the grouphead but instead of locking it in, just jiggling it around while water is dispensed through the head.
    Jul 2004
    2,120
    I have a Pallo coffee tool which I use to brush the group before each shot, whilst running some water through the group.
    I do a chemical b/f approx once a week depending on use.
    I currently do not take the group seal or screen off unless replacing one or both.
    Dec 2007
    921
    The brush does get deposits not reached by backflushing or juggling. How often you need to do it? Depends on use but I wouldnt say it was as regular as backflushing.
    Nov 2006
    1,077
    Hi All
    I backflush only when doing a clean every 2 - 3 weeks.
    I use the brush and a cloth to clean around the screen and only take the screen and seal out when i plant to replace the screen.
    Mal
    Dec 2004
    Earth!
    15,463
    Flush, brush, jiggle, and backflush after every pull. Chemical backflush once a week or more often as needed.
    Java "Keeping it clean" phile
    Nov 2008
    361
    I use the brush after each use. not a big addition to the routine, but helps to keep all areas clean as a whistle ;D
  1. Steam Arm Cleaning Brush
    By Thundergod in forum General Coffee Related...
    Last Post: 11th July 2011, 03:30 PM
  2. Catastrophe! Mazzer vs cleaning brush...
    By sdg in forum Grinders
    Last Post: 16th August 2008, 11:25 AM
