Results 1 to 13 of 13
Thread: thermometer with K type thermocouple
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Hi All
    I was at Jaycar the other day to pick up some food safe grease and found this small thermometer with K type thermocouple. I had a DMM in a mobile phone holder on the side to monitor the boiler temp but this is much easier on the eyes. It also has high and low alarms as well, the thermocouple fits neatly in with the thermostat probe on my Vibiemme Domobar.
    Cheers Gra…
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Re: thermometer with K type thermocouple
    Boiler view
    Mar 2004
    Internet
    17,551
    Nice one Gra although I think your boiler is running a little cool.
    Seriously good, simple mod!
    22a
    22a is offline
    Apr 2008
    94
    Thats neat. How much did it set you back?
    Jul 2008
    Port Fairy
    2,993
    Looks like a good one for lots of coffee stuff :) It will save me having the big multimeter on the bench.
    The only way it could be any better would be if it had a timer built in like I have seen a couple of American sites have had.
    Jaycar Link http://www.jaycar.com.au/productView...T&SUBCATID=694
    May 2008
    4,275
    Thats excellent Gra - a variation on the Gronk (Slivia mod). What sort of temps have you been noticing?
    It would be good to see how that compares to group head temp.
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Quote Originally Posted by 59534651515E4A4C3F0 link=1234874457/5#5 date=1234911544
    Hi Flynn
    The machine sits on 108* - 109*after warm up I do a quick 2 second flush Lock and pull the shot I have not checked the temp @ the group because what has been ending up in the cup is great,What I dont know won’t hurt me at the moment. I then purge the steam the temp rises to 130*+ in no time I start steaming milk after 2 bar boiler pressure. Then steam off hot water on prime boiler and the temp drops back 108* 109*ready to go again. :) :)
    Cheers Gra
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Quote Originally Posted by 6166626D656F7A6A6D64030 link=1234874457/4#4 date=1234909671
    Thats the one that I have but it only goes from 50* to 150*C and has high and low alarms.....Price $39.00..They do make another model that is -50* to 300*...Cheers Gra..
    Jun 2005
    116
    Quote Originally Posted by 4A7F6C0D0 link=1234874457/0#0 date=1234874457
    I was at Jaycar the other day to pick up some food safe grease andfound this smallthermometer with K type thermocouple. I had a DMM in a mobile phone holder on the side to monitor the boiler temp but this is much easier on the eyes. It also has high and low alarms as well, the thermocouple fits neatly in with the thermostat probe on my Vibiemme Domobar.
    Hi Gra,
    Does it have the normal TC connector to the display or is it hard wired to the display?
    cheers,
    James
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Hi Gra,
    cheers,
    James
    Hi James *
    Its hard wired with a 50 mm K type probe...
    Cheers *Gra.. ;)
    May 2008
    4,275
    I bought one of these on Friday and installed it as per Gras. Very easy, but not sure about the best place to run the cable. I ran mine up through the temp. adjustment access hole and out under the lid. I wonder what sort of temp the plastic insulation on the wire can stand. I tied it to the shielded hose that runs to the OPV to try to keep it from touching the copper tubing
    Ive been using it today (after buying a new battery) and noticing the temperature ranges between about 103º (after boiler refill) and 134º (steam temp) with around 110 - 111º idle.
    Jul 2008
    Port Fairy
    2,993
    Just revisiting this one again. I found a local source of a similar Thermometer with *a built in timer. Not cheap at $62 + postage. One source is http://www.hlpcontrols.com.au/prod04.htm Just the thing for manual brewer nuts like me *:)
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Quote Originally Posted by 38322730303F2B2D5E0 link=1234874457/10#10 date=1235270783
    Good one Steve, I ended up using heat shrink over the lead to protect it from hot piping and run my lead out through the bottom right hand side.....
    Cheers Gra....
  1. thermocouple type?
    By WSullivan in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th September 2014, 02:59 PM
  2. Fitting a bead type thermocouple (to a Silvia).
    By Toad in forum Brewing Equipment (non-machine specific)
    Last Post: 28th August 2012, 10:18 PM
  3. Thermometer
    By sugilun in forum Roasters
    Last Post: 5th November 2008, 06:39 PM
  4. Ozito heatgun meltdown and Type K thermocouple
    By Intellidepth in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 30th June 2008, 11:25 PM
