Results 1 to 9 of 9
Thread: Bean Age v Grind
    Apr 2007
    78
    Bean Age v Grind
    What is the general consensus [possibly an impossible outcome] of the direction of grind as the [roasted] beans age over a few weeks - finer or coarser?
    Yes I know that after a few weeks most beans would be considered stale and probably unusable by most of you experts, but I am just trying to find a starting point as it were for someone as inexperienced as I. I cant find much comment at all on this matter on this site, probably using wrong search terms, but I have heard that, as a general rule, as the beans age then you should use a finer grind. But I have also heard that as the beans age you need to grind coarser.
    Any views please.
    Oct 2007
    790
    Re: Bean Age v Grind
    my own experience is that as beans age (not always a bad thing, to a point) i go finer. i cant recall ever having gone coarser
    Dec 2007
    921
    I can vouch for the older beans going a bit finer, they are certainly not getting better when they are at that stage.
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Finer each day in my experience. Still learning to let them age a few more days. 11 days post roast was awesome today, thats almost a record for us.
    10,496
    Quote Originally Posted by 7F6869776263683C3F3C0D0 link=1239167814/3#3 date=1239183739
    Roast some extra and ask someone you trust to keep them away from you for at least 7 days.
    If you dont know anyone I can ask a certain black belt I know to keep them away from you. ;)
    Mar 2006
    703
    Generally it seems that as beans age the grind could go finer....based on reasonably consistent ambient conditions over the time of bean usage.
    One exception might be where you experienced higher ambient temperatures and very low humidity during the early days of bean use and then lower ambient temperatures and relatively high humidity during the later days of bean use, in that case you might find that a courser grind may be required.
    So it could be that someone has said they grind finer as beans age, and someone has said they had to grind courser, certainly I have noticed when weather conditions are volatile that the optimum grind can be difficult t maintain.
    Oct 2007
    New Zealand
    1,162
    Quote Originally Posted by 6854495258594E5B53583C0 link=1239167814/4#4 date=1239191485
    mmm...that may work TG but while he sleeps......... :D
    Apr 2007
    78
    Thanks guys. But I will pass on the black belt bit.
    10,496
    Quote Originally Posted by 5B4C4D5346474C181B18290 link=1239167814/6#6 date=1239262008
    "Sleep is overrated"
  1. Does bean weight affect grind?
    By DesigningByCoffee in forum Grinders
    Last Post: 24th June 2009, 09:41 AM
  2. The balance of grind, bean and extraction time.
    By sco in forum General Coffee Related...
    Last Post: 3rd March 2009, 12:57 PM
  3. Fine grind/course grind blend...How To?
    By reubster in forum Blending Room
    Last Post: 5th December 2007, 02:37 AM
  4. Bean Storage, Green through Grind
    By justintime in forum General Coffee Related...
    Last Post: 13th December 2006, 03:12 PM
