Results 1 to 10 of 10
Thread: Levelling the dose (or not)
    Apr 2007
    323
    Having watched Stephen Morrisseys WBC2008 performance recently, I noted he didnt level his dose. It was a 1/2 fill, single (gentle) tap, overfill to a heaped mound shape, another single tap and then tamp.
    http://www.worldbaristachampionship.com/
    Any thoughts?
    Epic76
    Dec 2007
    921
    Re: Levelling the dose (or not)
    Whatever gives you a good distribution leveling probably not necessary if you distribute properly from the grinder. But just because it works for him doesnt mean it will for everyone it is a finely tuned routine repeated to eliminate variation.
    Mar 2007
    203
    I suppose when your that experienced you can judge by eye that you have enough in the filter and the tapping and tamping does the levelling for you. Have done it myself on occasions but im no expert.
    Apr 2007
    1,687
    n.b. Stephen has a deadly BNZ conical grinder that has timed doses. It seems he has the set volume of coffee to be dosed and is just tapping to collapse the grinds so that it doesnt fall off the edges of the PF. As long as he sweeps the doser clean (which the BNZs do well) hell have the same dose each time. Just gotta pack that sucker and Roberts your dads bro.
    Apr 2008
    Brisbane
    5,117
    I dont level off the grinds
    My Macap M4D gives me the correct amount of ground coffee I require
    I tap the PF on the bench a couple of times and tamp
    Generally I can judge by eye if I have enough ground coffee so when I need to change the burr setting I can always put it on continuous for a quick burst if required
    It works for me as I need to tamp 8mm deep to clear the water screen
    Mar 2008
    466
    Quote Originally Posted by 7D61617E65040 link=1239701539/3#3 date=1239706795
    Nah he used timed anfim, it was dave that used the timer modded bnz. Same idea tho.
    Apr 2007
    323
    Thanks for your replies guys.
    I would have thought that in his situation, the dose would be quite consistent (same grind setting, taps to same strength, constant overflowing mound of coffee).
    My curiosity related to the resulting distribution. From heaped mound to flat puck. Wouldnt it make the centre of the puck more dense and promote channelling on the periphery? Clearly from the results thats not the case but I must admit I dont know why. A heavy Paul Bassett style updose and super-tamp?
    Epic76
    Apr 2007
    1,687
    Quote Originally Posted by 567A696F727A7744567475707E621B0 link=1239701539/5#5 date=1239710519
    oops, yeah totally, good pickup. cheers MM
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    To my way of thinking, levelling eliminates the need for eyeballing. If youre working in a cafe environment and dont level the dose surely it has got to save you time? I think that as you apply the tamp the grounds become evenly dispersed anyway.
    Since installing our BNZs I havent been levelling, and when I get it right, I certainly cant see or taste any difference. With another 1000 or so doses I might even be able to get it right blindfolded. ;D
    Mar 2008
    466
    However in WBC events wastage has to be kept to a minimum (i think it was changed to less than 1 gram per shot this year). So expect to be seeing much more of this in years comp.
  1. How big a dose do I get
    By nutfarmer in forum General Coffee Related...
    Last Post: 19th June 2011, 09:48 AM
  2. How much to dose
    By bennyhill in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd February 2010, 09:45 PM
  3. how to get the right dose ?
    By derrilex in forum General Coffee Related...
    Last Post: 20th August 2009, 09:12 AM
