Results 1 to 2 of 2
Thread: Coffee beans/grinding/grounds in Melbourne CBD ?
    Jul 2009
    8
    Hi Melbourne folks,
    Just wondering if there is a good place to source good coffee beans and a place that will grind to your specifications in Melbourne CBD areas ?
    Thanks.
    hazchem
    Re: Coffee beans/grinding/grounds in Melbourne CBD ?
    Hi WM and welcome to coffeesnobs.
    You should have a look at the following -
    http://coffeesnobs.com.au/YaBB.pl?num=1231309291
    http://coffeesnobs.com.au/YaBB.pl?board=VIC
    hopefully youll find all the info you need there.
    P.S. coffee is much better when ground fresh just before using.
  1. where can i buy good coffee beans in melbourne
    By moey007 in forum General Coffee Related...
    Last Post: 1st August 2007, 06:13 PM
  2. Where to buy coffee beans in Melbourne?
    By andrew in forum General Coffee Related...
    Last Post: 4th August 2006, 09:46 AM
