Results 1 to 13 of 13
Thread: Coffee machine for travellers
    Sep 2009
    4
    Hi - We are new on the site.
    We plan to go travelling in a caravan for a couple of years and wondered if anyone else had taken a coffee machine and what sort proved most suitable.
    Bazaar
    Apr 2008
    Brisbane
    5,115
    Re: Coffee machine for travellers
    For your purpose I feel a Lelit Combi is suitable also an Aeropress & Kyocera hand grinder for when no power is available
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 2C363130372D5E0 link=1254781111/0#0 date=1254781111
    Bazaar
    A stove top, a Presso, an Atomic etc etc
    Q1: Milk based drinks required ?
    Q2: What grinder will you be having.. Hand grinder ?
    Q3: What beans / self roasted on a Gas stove, Brown Bay, Supermarket ?
    Without some more info... You leave it wide open...
    14,666
    Quote Originally Posted by 17333A3A39390317332F31335C0 link=1254781111/1#1 date=1254781923
    Hi Bazaar,
    Should the Lelit prove to be the answer, they are back in stock at Talk Coffee and Cuppacoffee.
    May 2008
    4,192
    Quote Originally Posted by 7A606766617B080 link=1254781111/0#0 date=1254781111
    What AM says. Do you have a budget?
    I have been using the La Sorrentina Atomic recently and I am quite impressed with the quality of the coffee I have produced from it. The beauty is it is compact and you dont need electricity. It has a milk steamer which produces great textured milk with practice. I would recommend a grinder though unless you are prepared to use pre-ground.
    I also recommend the Aeropress as a very portable option. You prepare a couple of cups with a shot made with the Aeropress, add a bit more hot water and milk &/or sugar to taste and the result is very drinkable.
    I havent used a Presso but, if you usually drink black, I would say its a good option to consider.
    Sep 2009
    4
    HAVE COFFEE MACHINE WILL TRAVEL
    I did try to do this yesterday but must have failed.
    We plan on travelling by caravan for a few years and wondered if anybody else could recommend what short of coffee machine etc may be suitable to take with us.
    Our ECM is definitely too big and far too heavy.
    Any ideas from anyone? :
    May 2008
    4,192
    Re: HAVE COFFEE MACHINE WILL TRAVEL
    No, you succeeded. Here is your question and responses so far:
    http://coffeesnobs.com.au/YaBB.pl?num=1254781111/0#0
    I suggest adding to your old thread rather than this one.
    Nov 2008
    364
    hard to beat the aeropress for ease, durability and price. for $50 its probably a good addition to whatever machine you end up getting. I just took mine camping with a kyocera grinder, and the ribbing from my mates stopped when I made them a freshly ground coffee in the middle of nowhere...
    Caffeine Junky
    May 2009
    1,103
    Quote Originally Posted by 496D646467675D496D716F6D020 link=1254781111/1#1 date=1254781923
    I think this is pretty sound advice you could be set up with all of this for ~$1K. *
    To give the best advice wed need to know more about any restrictions/preferences you have e.g. size, weight, price? Are you always going to have access to power? *Also, what are you using for a grinder now?
    At around 10kg the Lelit Combi is relatively light and great value. *If theres only 2 of you then you certainly wont need a HX machine and the size/weight associated with it.
    14,666
    Hello Bazaar.
    Perhaps it might have been best to simply refer to your original post rather than just posting again? :-? You may not get the answers you had hoped for if you cross post. Your cross post now spliced to your original thread ::)
    Dec 2006
    59
    We have taken a Sunbeam 6910 with us - a bit heavy, but as it is now our backup machine, Im not too worried about it getting a bit of rough treatment.
    The main issue with it was that a honda eu20 genny really struggles to run it, as it is rated at over 2000w. I had to make sure EVERYTHING else in the van was turned off, and even then it struggled.
    So next time we may take our new toy, wrapped in cotton wool. Its bigger & heavier, but almost half the wattage.
    I dont know how big your home machine is, but if you can fit it in, I suggest that you take it. If you plan to run it off a genny, check the wattage. Ditto if you decide on a new machine.
    I must admit that it is very satisfying to pull up in the middle of nowhere & having a cracking coffee within 15 minutes *:)
    Sep 2009
    4
    We are keen on the advice from Koffee Kosmo of the Lelit Combi and an Aeropress & Kyocera hand grinder.
    Thanks all for your advice with this.
    Our Giotto is just to heavy to take and uses too much power.
    When we are heading off we will put our Giotto and our grinder up for sale so hopefully they will go to a good home.
    Apr 2008
    Brisbane
    5,115
    This is the Lelit Combi for "in caravan use" the grinder & machine is combined in one unit. Its on par or close to Silvia quality
    Watt 1200W element
    Dimensions 340 x 210 x 360mm
    Available from Talk Coffee (Melb) Cuppacoffee (Syd)
    The Kyocera hand grinder is similar in size to a small pepper mill
    The Aeropress is the size of a tall thin mug
    This combo is for times when you go hiking or when no power is available
    Easily fits in a back pack
    However you will need to boil water
  1. First time on Coffee Snobs and looking to purchase a coffee machine!
    By margaretm in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th October 2013, 12:03 PM
  2. Replies: 1
    Last Post: 8th March 2011, 07:55 AM
  3. Help,  any Sydney/Albury road travellers??
    By Lizzie in forum Off Topic
    Last Post: 26th August 2008, 06:56 PM
