Results 1 to 9 of 9
Thread: Automatic Timer Switch
    Jun 2009
    37
    Hey all,
    Anyone have a recommendation on an automatic timer switch suitable to switch on my machine once or twice a day? Is there a big difference between different models?
    Any help would be appreciated.
    May 2008
    4,211
    Re: Automatic Timer Switch
    I just use a common or garden variety one from Woolies - HPM brand. It switches on my machine twice a day: 6AM and 4PM
    Its been on my machine for at least the last 6 months without a problem.
    Coffee+carbon=heaven Mono's Avatar
    Aug 2009
    Regional Victoria
    760
    FP, I use a Arlec, it was the most compact digital timer I could find, Kmart was the best. Its programed to turn on @ 5:30 each weekday morning and on @ 7:00 on the weekends. No problems here. I think the main differences are # of cycles (on/off) that can be set. Of course there is the choice between mechanical & digital with the latter giving you a better choice with programing options.
    Steve
    Jul 2004
    2,134
    I use a digital one that I got from a website called catch of the day. It was under $20 and has the capability to do 20 different programs. I run 2 on/off cycles for weekdays and 1 for weekends. Ive had no issues with it, but its a no namer (probably a knock-off or a grey import of a better known brand like Arlec).
    Member Morgz's Avatar
    Dec 2009
    Perth
    96
    OK all you electrical wizzes... I am getting the nursery ready for the arrival of my new Izzo. When both the steam and brew boiler elements are on the draw is 2500W. I am planning to put it on a timer so that the brew boiler switches on and gets things nice and warm for my morning espresso by the time Im up. Ive got an Arlec PC888 electronic timer which would be great for the job but its rated at 2400W & 10A. Am I going to fry it with the Izzo when both the brew and steam boilers are heating? :-/
    ale
    ale is offline
    Sep 2010
    22
    the heating effect of your machine on the timer will be less than those due to a 2400W continuous load , as after warm up is done the elements will work on an on/off cycle
    then when timer switches off the machine, it will do it either with both elements off or with only one on or with both on....as you can see its very likely the life of your timer will be affected by those 100W more ....
    dont worry and enjoy that first shot !
    Jun 2005
    Newcastle
    230
    Quote Originally Posted by 13312C39245E0 link=1260967168/4#4 date=1293094528
    My understanding is that the Duetto comes setup for a standard 10A max power point - the PID is configured to only power one boiler at a time (brew boiler priority) - also, dont forget to add 100-150W for the pump to the total.
    Unless you have a 15A power point for her and request it configured for such (or change the PID setting yourself).
    Dec 2009
    Perth
    96
    The Duetto does have a low power mode which prioritises the brew boiler and draws (I think) 7A, I think youre correct that its set to this mode by default and the reviews Ive read seem to indicate that in a domestic environment it doesnt hurt performance much. I guess Chris will be able to clarify that for me. The two boilers have separate switches so as long as I remember to turn off the steam boiler when Im not using it, the power draw shouldnt be too bad. I guess Im answering my own question... the 2400W rating of the switch should be OK *:) Thanks for the advice guys..
    May 2010
    349
    Mine is push button on, and it defaults to off when switched on at the mains, so I cant use a timer with it - bugger!
  1. K3 Dose Timing - Countown Timer Switch?
    By Rusty in forum Grinders
    Last Post: 12th April 2010, 01:07 PM
  2. Automatic timer switches
    By Gavin1 in forum Brewing Equipment (non-machine specific)
    Last Post: 5th October 2009, 10:37 AM
  3. Mazzer super jolly automatic (timer?) question
    By Neekolas in forum Grinders
    Last Post: 12th May 2009, 07:45 PM
