Results 1 to 18 of 18
Thread: Basket stuck! Emergency! :O
    Oct 2009
    Geelong
    1,169
    Hey guys! I recently ordered a new 14g portafilter basket for my Gaggia Classic, but as i inserted the portafilter in and took it out, the actual basket got stuck in the group head! :O:O:O Freakin out! Have tried prying it out with a knife, and running water through it, still stuck!!!
    Any instant advice? :( Should i shrink the basket with cool water.. if thatd even work??
    Apr 2008
    Brisbane
    5,115
    Re: Basket stuck! Emergency! :O
    Tap it off
    Think of it as a bottle cap
    Oct 2009
    Geelong
    1,169
    Tried that, didnt work... i even just tried to use my tamper to knock it off.... I should not have done that... as ive made a visible dent in the basket now :(... Cheers though KK...
    Apr 2008
    Brisbane
    5,115
    Can you use a lever to prize it off from up on the contact point and use the group head as the fulcrum
    Oct 2009
    Geelong
    1,169
    Yeah ive tried inserting the handle of a spoon to pry it out, knives... I can reach the edge of the basket so there is a lever method going on, but still doesnt budge...
    Hmmm... actually... ive been trying to cool it down so it shrinks (using frozen veggie bags :P), but wouldnt it be a better idea to heat the basket so it expands and thus it wont be stuck anymore? Hmmm... Am gonna try to warm up the machine now and see...
    Apr 2008
    Brisbane
    5,115
    Only warm up the basket
    This will expand it a little and may loosen it
    Use a bowl of hot water and lift it up to submerge the basket
    Do you have a pair of adjustable pliers as they would be perfect for this job
    Oct 2009
    Geelong
    1,169
    Ah ok... no i dont have pliers like that... i just tried.... OH!!!! :D:D:D:D:D:D After trying to knock it out, i put down my tool, accidently brushed it, and it just... FELL out!!! SOOOO stoked!!!!! yay! I think maybe its cos i turned off the machine and it cooled down a little after being pretty heated... Now im wondering whether i should try to use it again or not... :S
    Thanks heaps for your advice KK, really appreciate it! :D
    Apr 2008
    Brisbane
    5,115
    Good to hear that you are back on track
    Dont risk it by using it again without first inspecting and determining the difference of the rims on the good basket to the bad basket
    The inside rim on the new basket may have a smaller diameter that has caused all your problems
    Oct 2009
    Geelong
    1,169
    Yeah... i just tried to put it in again but only lightly... and lo and behold it got stuck again. Could easily pull it out again as i didnt jam it in.
    Yeah i see now there is a definite difference between the proper size basket and this one... Hmmmm... im going to have a word to the supplier who told me personally that yes it is compatible for my Gaggia... grrr I had a laugh.
    May 2008
    4,192
    Did the new basket come with a spring? If so, use that spring instead of the Gaggia one which will secure it in the group handle better.
    If the basket didnt come with a spring, see if you can get one from the place where you ordered the basket. Try Coffee Parts if they cant help.
    Oct 2009
    Geelong
    1,169
    No it didnt come with a spring... didnt realise there was a spring that could be used :S. Not sure what you mean sorry...
    Dec 2009
    104
    on the inside of the group handle there should be a wire, that sits mostly in a grove, that is the spring that holds the basket in place.
    10,496
    Flynn I think the problem is not that its not a good fit in the group handle but that the internal diameter of the basket is too small for the shower screen and jams on there.
    May 2008
    4,192
    Quote Originally Posted by 4D716C777D7C6B7E767D190 link=1274655615/12#12 date=1274668719
    I dont know about that TG. It may be possible that the basket is not a good fit but I do know:
    - not all baskets fit the same and some come with a spring designed to hold a particular basket.
    - I had the same problem about baskets getting stuck with the Gaggia Baby. It didnt jam but it could be pretty hard to remove until you you got at it a certain way and then it came off easily.
    simonsk8r: The spring is shown here (the first part shown at the top):
    http://www.coffeeparts.com/gaggia/gaggia-spare-parts-3.html
    Also, get in the habit of removing the grouphandle/ portafilter from the grouphead as soon as the shot is poured. Mine usually got stuck if I left it in place.
    10,496
    Quote Originally Posted by 243E3A3839243C6F25570 link=1274655615/4#4 date=1274657464
    Well agree to disagree.
    OPs description seems to me to describe "stuck tight inside the group head".
    May 2008
    4,192
    Quote Originally Posted by 1C203D262C2D3A2F272C480 link=1274655615/14#14 date=1274684915
    Until you read his later post......
    Quote Originally Posted by 3B212527263B23703A480 link=1274655615/6#6 date=1274658335
    Oct 2009
    Geelong
    1,169
    Ah okay, thanks guys! The supplier actually were fantastic and called me up after i sent an email, and he explained about the spring actually. He said theyll send a new basket that didnt have an indentation round the outside (just below the rim), ie a flat walled basket and see how that goes! Maybe im guessing its to do with the spring, not 100% sure... but very thrilled bout that!
    Cheers guys! :)
    May 2008
    4,192
    Quote Originally Posted by 23393D3F3E233B6822500 link=1274655615/16#16 date=1274707476
    Its almost definitely the spring. They originally provided you with a ridged basket without the proper spring for it. Well I hope the ridgeless basket does the job, but dont forget my advice about removing the grouphandle straight after the shot is finished
  1. Lelit - Filter basket getting stuck
    By vjrossi in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd May 2011, 05:19 AM
  2. Single basket, stuck puck
    By JJJ in forum General Coffee Related...
    Last Post: 1st July 2010, 11:23 PM
  3. stuck basket
    By Sunbeamer in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd October 2007, 11:42 AM
