Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By flynnaus
Thread: Sealing 250g Stand-up Valve Coffee Bag
    Apr 2009
    20
    Hey all,
    I have been roasting for a while and send some close friends a batch of my roasted coffee regularly for them to taste and critique. I am finding that the 250g Stand-up Valve Coffee Bags with click-zip closure are great although they some times pop open when posting. How do you seal them. Iron, Hair straightener????
    Fat Mac
    Nov 2010
    448
    Re: Sealing 250g Stand-up Valve Coffee Bag
    If you want to seal them, you need to buy ones that are made to be sealed such as the ones on this page: http://www.coffeeparts.com/coffeebags/bags.html
    Im not sure if the coffeesnobs ones can be heat sealed, but if they can, you need a heat sealer, though I cant see why a hair straightner wouldnt work.
    Nov 2008
    9
    I can vouch for the hair straightner I used one for a year or so before I lashed out on a heat sealer it worked a treat!
    Jul 2004
    2,125
    I just used an iron until I bought my heat sealer.
    They are commonly called impulse sealers and I use mine every week when I roast for others. The zip lock alone is too risky IMO for mailing.
    Do a search on the bay of evil if you want to see what they cost. Or stick with the hair straightener / iron.
    Apr 2009
    20
    Thnkyou all is it just direct heat to the bag or through a tea towel.
    Jul 2004
    2,125
    With the iron, I used to just place it on directly. I guess it depends on your iron though. If it does not have a non-stick coating, you might like to do it via brown paper or tea towel etc.
    It only requires a very short application. Even with the purpose built thing, the heat is only applied for a few seconds.
    Also, dont seal ALL the area available otherwise it makes it very hard to open.
    Feb 2010
    16
    I got some plastic clamp/clips from a "big multinational Swedish house/furniture store" and clamp them over the top of bags that come author a zip lock. They are like two plastic strips that push together with the bag between them, giving an airtight seal.
    Oct 2006
    504
    another ironer here when i used to buy my own browns, worked a treat for me
    Sep 2010
    112
    Should I check with the wife before I use her hair straightener?..... :-/
    Sep 2009
    Sydney Inner West
    132
    Quote Originally Posted by 786760636A7C67607B6E6360796A0F0 link=1295861552/8#8 date=1303092176
    Wholeshotalove... Highly recommend it .. never want to mess with the missus GHD mate ..
    Nov 2010
    369
    alternatively would packing tape folded over give extra security if only a few bags are being posted?
    Junior Member Sean881's Avatar
    Sep 2012
    Townsville QLD
    12
    I have recently purchased an impulse sealer, PFS-300 450watt, and some silver 250g bags of evil bay. However I can not get it to seal near the bag seam or the flap ends ? Have I missed something? Do I now have 200 crap silver bags :-)
    Cheers Sean
    May 2008
    4,096
    Impulse sealer, PFS-300 450watt, and some silver 250g bags of evil bay. However I can not get it to seal
    I have one of these sealers. It doesn't have much trouble with the stand-up bags. Are you holding it down until the light goes off? If not, then that's the problem and you might need to RTFM.
    If you are, then you may need to turn it up higher. If it is already maxed out (or close to), then try swapping to the spare wire (if they provided one). If that doesn't help (or you don't have a spare, contact the seller as it sounds like yours is faulty
    Thundergod likes this.
    Senior Member GrahamK's Avatar
    Jun 2009
    Ormiston - Brisbane
    542
    Quote Originally Posted by Sean881 View Post
    and some silver 250g bags of evil bayCheers Sean
    I used some of those bags once, and did find I had to crank up the power to ensure they sealed properly.
    And as Flynnaus mentioned - hold it down at least until the light goes off and buzzer stops and then a bit more to ensure a good seal.
    GrahamK
  1. When a 250g bag of beans doesn't contain 250g of beans
    By Jonathon in forum General Coffee Related...
    Last Post: 27th June 2013, 12:29 PM
  2. Sealing Group Heads to boiler pipes- do I need a sealant?
    By koligi in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 20th February 2011, 05:33 PM
  3. Venus not sealing anymore :(
    By shizzle in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th June 2009, 10:26 AM
  4. 1-Way valved coffee Bags are they sealing ?
    By mick14jah in forum Roasted Bean Storage
    Last Post: 28th March 2009, 08:02 PM
