Results 1 to 4 of 4
Thread: What is the best water filter to use for a coffee machine?
    Feb 2009
    2
    I have bought an Olympia Cremina manual lever coffee machine. Does anyone know:
    1. What the best water filter is for a coffee machine? How much do they cost and where can I buy it from?
    2. Do I have to have a plumed in filter, or can it be avoided?
    3. What is the cheapest method I can get away with ie. can I use a Brita water filter jug with boiled water?
    4. Does Reverse Osmosis take out all impurities and scale?
    thanks, mike61 :D
    Jul 2008
    Port Fairy
    2,993
    Re: What is the best water filter to use for a coffee machine?
    Water filtration is a can of worms* ;)
    What is the correct water filtration depends heavily on what water you have to start with. anything from a brita Jug up to R/O is the right answer.
    The water filtration primer here is a good place to start http://coffeesnobs.com.au/YaBB.pl?num=1300415170
    I have just recently moved house and the new place has a water tank while the town is on artesian bore 800mg/l water :P Due to the proximity to the coast the tank supply is heavily tainted by salt and personally undrinkable in coffee. Currently using R/O water :-)
    So more info needed and welcome to the lever gang too 8-)
    Feb 2009
    2
    Thanks for that.
    It is a brand new coffee machine that I have been researching and waiting for for a long time. I am looking forward to it arriving from the manufacturer in Switzerland (Olympia Express) where it is being built as we write!
    It seems pretty unanimous that I should test the tap water with some test strips. I did call the water corp and they gave me a reading for my area of 0.89 to 1.45 millimol/L which I think can be converted into milligrams/L by timesing it by 18 which is the molecular weight of water. If that is correct, which I am a little unsure about, then the water here is actually quite soft 16 to 26 milligrams/L. It kinda sounds too good to be true though.
    I have been researching the Brita C150kit. Has anyone heard about it and whether it is any good?
    Also, Bombora do two types of filters:
    1. Scale inhibitor
    2. Water softener which works on ion exchange
    Does anyone know which one would be better for filtering the most minerals out of water?
    thanks, Kratos06
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 292D272C252128332B2B2820362D202321440 link=1301796582/2#2 date=1301998837
    * *1. Scale inhibitor
    * *2. Water softener which works on ion exchange
    * ** *Does anyone know which one would be better for filtering the most minerals out of water?
    Call and chat to Bombora. They are a sponsor and they will know the best fitout.
  1. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 01:53 AM
  2. Using a fridge water filter for a coffee machine??
    By Mischa in forum General Coffee Related...
    Last Post: 3rd November 2009, 10:19 AM
  3. Tap water or distilled water in coffee machine?
    By Blumack21 in forum General Coffee Related...
    Last Post: 31st October 2009, 11:46 AM
