Results 1 to 8 of 8
Thread: Cleaning your machine
    Jun 2008
    120
    Hi all
    How do people best clean the outside of there stainless steel machine? I used the stainless steel wipes but I dont think they work great with the heat. My machine is looking a bit blotchy and would live to return it to its original beauty
    16,863
    Re: Cleaning your machine
    Gday kanda... :)
    The best method Ive found over the years, is to use two decent microfibre cloths. One damp (with filtered water of course ::)) and the other dry.
    Wait until your machine has cooled down and then wax-on with the damp cloth and wax-off with the dry one immediately afterwards. Do small sections at a time like this to avoid allowing the dampness to dry out, then your machine will always look like new. 8-)
    No chemicals allowed near my Extra.... :P
    Nov 2010
    448
    I use white vinegar to get the marks off, then filtered water, then dry cloth. Make it sparkle like new :)
    The cloth I use to do it is one we use at work that we get from a wholesaler - Chux Masslin. I think they can only be bought in rolls of 65m for around $40 though, so theyre not cheap, but great for household cleaning, and dont fall apart at all (made of Rayon).
    Caffeine Junky
    May 2009
    1,103
    Quote Originally Posted by 64494D414C200 link=1302871193/1#1 date=1302876506
    Gday kanda... :)
    Same here, microfibre cloths are great. Dont find a need for any chemicals.
    Oct 2010
    483
    Since Im in a pedantic mood, Ill point out that water is a chemical...
    150
    I use a water/vinegar mix in a spray bottle (I use that for most cleaning jobs around the house). Spray, wipe clean with a wet cloth, then imediately shine with a paper towel.
    16,863
    Quote Originally Posted by 370C130B0611630 link=1302871193/5#5 date=1303070258
    I use a water/vinegar mix in a spray bottle (I use that for most cleaning jobs around the house). Spray, wipe clean with a wet cloth, then imediately shine with a paper towel.*
    Need to be careful using paper though, as it can be abrasive and eventually cause crazing to the surface. Hard to beat plain water with no additives and a little elbow grease. My machine probably looks shinier now than it did after first unpacking it.
    Great invention, microfibre cloths.... 8-)
    150
    Cheers for the tip Mal :)
  1. Machine maintenance & cleaning
    By mmmcoffee in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th March 2009, 12:51 PM
  2. Machine needs cleaning
    By niallpedlow in forum Brewing Equipment (non-machine specific)
    Last Post: 8th November 2006, 03:22 PM
  3. Commercial Machine Cleaning
    By Flo in forum Brewing Equipment (non-machine specific)
    Last Post: 6th November 2006, 11:24 AM
