Results 1 to 6 of 6
Thread: what to filter with
    Apr 2011
    152
    what to filter with
    I have used a Brita jug with the filter in it for a couple of years when refilling my old Saeco and probably need to get something a bit better for my new machine that I hope to have in July so what should I get that doesnt have to be hooked up to my tap and filters all the undesirables out? What exactly do I need to be filtering out?
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    Re: what to filter with
    First you need to find out if you actually have any undesirables. I did a test on the water out of my tap and we got zero ppm, do we filter or not, that is the question and there isnt just a one solution for all answer!
    Dec 2004
    Earth!
    15,667
    Have you read this thread yet? http://coffeesnobs.com.au/YaBB.pl?num=1300415170
    Java "A good starting point!" phile
    Aug 2004
    2,312
    The baddies are anything that cause scale. You cant "filter" them as they are "in solution" ie they are not "particles".
    The simplest things is to check with your local water business, explaining you want to keep scale out of your coffee machine/.
    Rgdz,
    Attilio
    May 2010
    137
    i ordered this one today
    http://www.fridgefilters.com.au/product.php?productid=18098&cat=0&page=1
    its been recommended on other threads if plumbing isnt an option
    this might help if you are in sydney, but its easy to check the water actually coming out of your tap with strips you can get from bombora
    http://www.sydneywater.com.au/Publications/Reports/TypicalWaterAnalysis.pdf
    Apr 2011
    152
    that looks like what i want for my set up, I think the water in my area is pretty good quality but Ill give bombora a ring and get some test strips.
  1. EM6910 - filter jug in place of calc filter?
    By Bremmario in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th April 2011, 06:17 PM
  2. paper filter in bottom of espresso filter basket
    By stuartgrant in forum Brewing Equipment (non-machine specific)
    Last Post: 7th August 2008, 12:49 PM
  3. Paper Filter for Percolator (to filter diterpenes)
    By xtg in forum Brewing Equipment (non-machine specific)
    Last Post: 1st October 2007, 11:19 AM
