Results 1 to 23 of 23
Thread: Difference between Piccolo latte and short macchiato?
    Member Angusw15's Avatar
    Oct 2011
    50
    In my 2 years of drinking coffee so far, I have normally had a latte or cappuccino (and the odd mocha I have to admit). Im thinking of changing it up a bit and trying other varieties. I looked it up on google and they look similar. Would anyone be able to explain the difference?
    Aug 2011
    98
    Re: Difference between Piccolo latte and short macchiato?
    A short Macchiatto? Similar to a latte? I think youre confusing it with a top up long macchiatto.
    A short macchiatto is just a shot of espresso with a cap of milk/foam. A traditional long macchiatto is a double shot with a cap of milk/foam. A top up long macchiatto is a double shot with milk topped up to the rim of the glass (150 - 200mL?) Not exactly sure on the amount.
    And since you like milk why not try a flat white?
    Senior Member yabba's Avatar
    Feb 2009
    Adelaide
    128
    Hey GenYguy,
    Always happy to be corrected as Iím not as learned as most on here however I have always believed that the Macchiato is the shot of coffee with a small spoon of foam / milk where the Piccolo is a 30ml shot and 30mls milk. If Iím wrong I have been driving the poor baristas of Australia mad because that is what I expect when I order a Piccolo. It would explain a lot of the strange looks !!
    Cheers Bryan
    Oct 2011
    50
    I once had a short black, didnt like it but I know these kinds of tastes grow on you and Im up for trying them again. :) Ill try a piccolo latte when I go for my coffee today.
    Mar 2009
    37
    it looks to me that you are debating on something like: is coffee with milk better than milk with coffee?
    I might sound a bit dry. maybe am having a bad day. :-[
    Oct 2011
    50
    No, I like coffee with milk but I am trying to expand my tastes to like coffee without much milk too.
    Jun 2008
    Cannington
    24
    Macchiato is basically a short black and a dash of froth
    and Piccolo latte is translated as small/short latte..so piccolo latte is a short black with little bit of milk and froth..
    For piccolo latte normally served in a bit taller shot glass
    Nov 2010
    Melbourne, VIC
    185
    I would have thought that the piccolo latte would still have the same proportions as a standard latte,
    so perhaps a single ristretto topped up with milk?
    May 2007
    301
    Hi all
    stealing part of a post from scoots back in 2006 -
    the baristas bible, Barista Techniques says that a Piccolo Latte is
    "A version of a caffe latte served in a macchiato glass"
    Should be based on an espresso - so 25-30ml of coffe or a ristretto- 15ml-20ml, topped with milk, and have 5mm of foam.
    So being as a macchiato glass can be anywhere from 70ml to 90ml in size, I guess you could end up with a 90ml Piccolo latte.
    I use a 90ml glass and find this great.
    As to a macchiato -
    My thoughts are it is an espresso shot "marked or stained with milk" - some will dolop a teaspoon of foam on top, some will heat milk and add a dash.
    I find these two drinks are very different beasts. If you are usually a milk based coffee drinker then the piccolo will be by far the smaller step transition to espresso.
    Oct 2011
    50
    Had a piccolo latte this morning and I liked it! Not as bitter as a short black but a pleasant change to the more milky coffees. Thanks for the info guys.
    Nov 2009
    Altona, Melbourne
    1,578
    Im a fan of the piccolo latte, never had a macchiato though, maybe I should :D
    150
    Quote Originally Posted by 7076616A70776F6D040 link=1317821832/10#10 date=1317964013
    Just Wow. Yes you should. :)
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,085
    I only get to make coffee on my machine on holidays and weekends, so one coffee is never enough. I usually have a Piccolo Latte followed immediately by a Macchiato. This is a nice combo as the Latte is a perfect first coffee of the day that doesnt fill me up with milk, and the Macchiato allows me to enjoy the essential nature of whatever bean is being used.
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    A piccolo should be a signature beverage for any coffee establishment - so at my work we fine the grind, and run a restricted double ristretto to 20mls served in a 90ml demitasse - then top with textured milk
    The coffee base should punch through the milk but not overwhelm the beverage, and should showcase the single origin (if thats what youre serving) of the coffee
    For a long mac I prefer an updosed restricted pour of no more than 40mls coffee, topped by a thin layer of testured milk - and a dash of cold milk to cool it all down a bit...
    Oct 2011
    16
    I find ordering from place to place differs greatly in terms of the language one must use to get what you want. I fear most places would look at me like I was insane if I asked for "a long mac, up-dosed restricted pour of no more than 40mls coffee, topped by a thin layer of textured milk, and a dash of cold milk to cool it all down a bit"
    Was at the maling room the other day and had a massive language barrier struggle with an asian waitress. All I wanted was a flat white with a double shot in it.
    Jan 2010
    57
    I once received a flat white (or something to that effect) in a 150ml ceramic cup when I ordered a piccolo with a double in it from another Melbourne cafe that should know better. I sent it back and was told by the waitress that you could not fit a double piccolo in anything smaller, while the 12 year old barista gave me a dumb look.
    In perth when I ordered a piccolo from another "A Lister" I got another huge drink in what was served in a cocktail glass.
    I now mainly drink without milk. Can I suggest you search out some professionally made single origin coffees to try from a good cafe. Im not that into blends straight up, but love single origins - and you will too!
    Sep 2010
    112
    Opinion.............. :D
    Junior Member alfadrian_syah's Avatar
    Oct 2011
    18
    I have should macchiato and Piccolo latte... ::)
    May 2008
    Central Queensland
    1,085
    When I first got seriously into coffee I went through a phase of wanting "custom-made coffees" when I went to a cafe. I soon realised that it was unreasonable to expect a busy Barista to custom-make my coffee based on the explanation of the Waitress of what I said to her. I now stick exclusively to what is on the menu board, and avoid mickey mouse concoctions like long Macchiatos that are open to interpretation. If I want to drink unusual combinations, I do them at home. Is there such a thing as a long Macchiato in Italy?
    Jul 2007
    2,286
    Usually, when you order a coffee in Italy, you are standing at the bar, talking to the barista, and about 3 or 4 feet from the machine.
    Even with my limited Italian I had no trouble getting what I wanted.
    Oct 2011
    50
    double ristretto long mac :D I have liked the piccolo and short mac as well and order them around once a week. Short black though is too much for me, I need SOME milk in my coffee! :P
    Jan 2011
    249
    One thing that this thread has highlighted is that how certain coffees are made is up to significant interpretation.
    When I do go out for coffee, I just order something from the menu. If they do a good job of it, Ill come back, if they dont, I wont.
    In my opinion, a piccolo latte has more milk than a short mac, which traditionally is just a stain of textured milk.
    The best thing about being behind the machine is you get to make yourself whatever you want ;-)
  23. #23
    Jun 2010
    Tasmania
    31
    After making macchiatos for others, I decided to try one for myself for the first time the other day. Even with the splash of milk and the dollop of foam, it still only tasted like a short black to me. If I go out to a cafe Ill ask for a latte in a cappuccino cup because an 8oz latte glass is too milky. Sometimes I get what Ive asked for, sometimes something completely different! When making my own coffee I like a latte in about a 130ml cup and I can also practise my art at the same time. ;D
    Why is there such a wide range of interpretations of drinks when ordering a coffee, is it lack of education or do cafe owners just make it up as they go along?
  1. Steaming for macchiato/piccolo
    By David8 in forum General Coffee Related...
    Last Post: 13th December 2016, 08:11 AM
  2. good latte macchiato blogs or articles?
    By derrichtige in forum General Coffee Related...
    Last Post: 28th February 2013, 04:32 PM
  3. A basic question: What is the difference of a latte and a strong latte?
    By cherni78 in forum General Coffee Related...
    Last Post: 9th October 2012, 05:03 PM
  4. cataldo, ristretto, piccolo latte. difference?
    By cataldo_lover in forum General Coffee Related...
    Last Post: 17th December 2008, 02:54 PM
