Originally Posted by
487C6B7D66514D6168686B6B0E0 link=1322997464/18#18 date=1323323508
Yes, increase the dose slightly, and dont forget that when you increase the dose you wiill probably have to coarsen up the grind by one step.
A puk that is not rock hard is fine as long as it ends up dry and comes out in one basic lump upon ejection. Sloppy puks usually mean low dose / and grind too fine, and they come out very very messy leaving sticky dregs in the filter. That is what you dont want.
When silvia is overdosed she leaks over the top duing brewing, so she will tell you when you went too far, but also with silvia she hates being underdosed and will tell you simpply by not giving you a great result on the palate.
Rgdz,
A.
