Results 1 to 3 of 3
Thread: Air flow problems
    dean_13
    Air flow problems
    hey fellow Coffee Snobs im having a problem with with some of my blends i seem to be getting a slight "bitterness"when im cupping my samples. my roasts are still dropping at around the same times(14 mins) but ive noticed my air flow is about 5-10 deg hotter than usual ,will this slight change affect my profile that badly?Any advice as im a self trained roaster and struggling to work this out :-/
    Mar 2004
    Internet
    17,522
    Re: Air flow problems
    Welcome to CoffeeSnobs Dean
    Quote Originally Posted by 2524202F1E7072410 link=1332389671/0#0 date=1332389671
    Sure could.
    If you didnt change anything else and have 10C air temp change... and assuming that the ambient temperature is similar then clean your flue/exhaust.
    Build-up on that side of the roaster will slow the exhausting air and add more heat thus changing the profile of the roast through the duration.
    (with a greater change at the end)
    dean_13
    Thanks Andy ill give that a shot i must admit this was "doing my head in"...... :)
  1. Pressure and flow
    By gonzob in forum Brewing Equipment (non-machine specific)
    Last Post: 19th February 2012, 12:39 PM
  2. Gaggia baby dose flow problems !!
    By hazza_jm in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 30th January 2012, 03:00 AM
  3. [m]: Restricted Flow
    By Dimal in forum General Coffee Related...
    Last Post: 14th May 2007, 04:24 PM
